Secure pasting is not working (4.1 testing)
Hello,
I’m recently experiencing some issues with the secure copy/paste feature in 4.1. I can copy correctly (clipboard manager shows the correct size of content) but the secure pasting isn’t doing anything. I’ve already tried to change the key combination but the same issue remains (copy works/pasting doesn’t).
I’ve also tried to run xev to see if the key combo isn’t picked up somehow, but both ctrl+shift+c and ctrl+shift+v are behaving the same.
I’m running out of ideas how to debug any further, so I’m looking for any additional suggestions…
A quick update:
After some desperate searching through the forum and trial-and-error, this finally helped to resolve my issue.
To spell it out explicitely, the solution (for qubes-gui-dom0 version 4.1.17) for was to run the following in dom0:
sudo systemd enable qubes-qrexec-policy-daemon
sudo systemd start qubes-qrexec-policy-daemon
