Did anyone consider, or even tried to set private instance of searx? How it would impact overall performance?
If acceptable, would it be installed in a separate qube, something like:
Ah, thanks. When the step is in the subject and not a goal… That’s why I didn’t find it when creating topic, but hopefully we will hear some more opinions and experiences, more importantly.
I guess I’ll try it at some point…
Meanwhile, when you said this,
I’m not sure how would I use it? Do you have an idea?
Not familiar with how searx, I may give it a go at some point.
You might have to use socat to open up a TCP channel or you might be in luck if you can reach it via the assigned IP.
