Scripting template admin commands that require no running user processes
In a template I want to change the user ID from 1000 to something else:
root@templatevm:~# usermod -u 1005 user
usermod: user user is currently used by process 691
Ok. Maybe then I might try stepping back to single user mode rather than whack-a-mole with running user processes that auto restart:
[user@dom0 ~]$ qvm-run --pass-io -u root templatevm "systemctl isolate rescue.target"
[user@dom0 ~]$ qvm-run --pass-io -u root templatevm "ls"
2025-11-16 11:33:24.521 qrexec-client[408964]: qrexec-daemon-common.c:232:connect_unix_socket: connect /var/run/qubes/qrexec.templatevm: No such file or directory
2025-11-16 11:33:24.521 qrexec-client[408964]: qrexec-daemon-common.c:29:negotiate_connection_params: write daemon: Bad file descriptor
… Not too surprising this didn’t work (even with --no-gui).
What does work is to reboot and login to a root console with qvm-console-dispvm and then type in my admin commands there. But that’s not scriptable, I don’t think. I could also bypass usermod and/or groupmod and just edit /etc/passwd and /etc/group directly:
qvm-run --pass-io -u root templatevm "sed -r -i 's/^user:x:1000:1000:(.*)/user:x:1005:1005:\1/' /etc/passwd"
qvm-run --pass-io -u root templatevm "sed -r -i 's/^user:x:1000:/user:x:1005:/' /etc/group"
But that’s hacky and gross and surely incomplete.
So what would be the right way to approach this instead?
Using salt?
You’re surely right. I’ve been able to evade salt for template shaping and qube orchestration for years now through abuse of qvm-run. I like the non-abstraction and easy debugging and composability of shell scripting, but there is a limit, and this at least rubs up against it.
Anyway, here’s a race-y and wrong way to do it that works:
change-user-id.bash
#!/bin/bash
set -euo pipefail
set -x
QUBE="$1"
NEW_ID="$2"
script=$(
cat <<'END'
#!/bin/bash
set -euo pipefail
set -x
NEW_ID="$1"
sessions="$( \
  loginctl --no-legend list-sessions \
  | awk '{print $1, $3}' \
  | grep '\<user\>' \
  | awk '{print $1}'
[ "$sessions" ] && loginctl terminate-session $sessions
sleep 2
pkill -u user || true
sleep 2
pkill -u user --signal KILL || true
sleep 2
usermod -u $NEW_ID user
groupmod -g $NEW_ID user
chown -R user:user /rw/home/user
END
echo "$script" | qvm-run -p -u root "$QUBE" 'cat > /root/temp.sh'
qvm-run -p -u root "$QUBE" 'chmod u+x /root/temp.sh'
qvm-run -p -u root "$QUBE" "systemd-run /root/temp.sh $NEW_ID"
sleep 20
qvm-shutdown --wait "$QUBE"
qvm-start "$QUBE"
qvm-run -p -u root "$QUBE" "rm /root/temp.sh"
Run:
[user@dom0 ~]$ ./change-user-id.bash <template> <new user/group ID number>
Salt it like this:
/srv/salt/test/configure.sls:
logout_user:
  cmd.run:
    - name: "kill -9 $(pgrep -u user)"
change_useruid:
  user.present:
    - name: user
    - home: /home/user
    - allow_uid_change: True
    - uid: 1010
change_directory_owner:
  file.directory:
    - name: /home/user
    - user: user
    - recurse:
      - user
sudo qubesctl --skip-dom0 --show-output --targets=TARGET_LIST state.apply test.configure
That’s a lot cleaner.
I wonder what the equivalent Ansible solution would look like. Not that a third solution is needed, but it would be interesting in a Rosetta Stone sense.
Something like change_uid.yaml :
- hosts: testqube
  connection: local
  tasks:
      - name: Kill user session
        ansible.builtin.shell: |
          pkill -u user
      - name: Change user uid
        ansible.builtin.user:
          uid: 1111
      - name: Check file ownership
        file:
          recurse: yes
          path: /home/user
          owner: user
ansible-playbook -i inventory change_uid.yaml --user=root
Thanks for humoring the question @unman!
So the code/conf is really quite similar, which makes sense, both of them being YAML-ish, and the material distinctions between the technologies being largely backend/architectural. :+1:
