Screencasting from Qubes OS
For quick tutorials and demos, I make screencasts to share with clients and colleagues, typically using OBS Studio. What is a sane approach to achieving this in Qubes OS?
Required:
  • Screencast of mouse pointer and multiple Windows
  • Real-time voice recording
Nice to have:
  • Real-time webcam recording
  • As viewed from dom0 (to demo Qubes OS itself, but this is low priority for me)
Options that I can make out are:
  • Running an AppVM in full-screen mode, giving it access to the mic/webcam, installing OBS Studio and making screencasts in that context
  • As above without full-screen mode, not clear to me what this would look like
  • Installing OBS Studio (or some other tool) in dom0, and recording the whole Qubes OS desktop, but even if possible I assume this is not a good idea
Are any of these options obviously worth/not worth pursuing? Any options I’ve missed?
This seems to work well with OBS Studio, though it doesn’t give you the dom0 view:
Create a nested X server via Xephyr. The Arch Linux wiki has a good description of how to do this: https://wiki.archlinux.org/index.php/Xephyr . Then share the nested X server. You can have an arbitrary number of windows there and even start any window manager in this X server instance.
Capture card setup
There is also this setup I found interesting:
Qubes —HDMI—> Capture Card (HDMI to USB) —USB–> Qubes → AppVM w/ OBS → jitsi
Explanation from within Qubes (youtube link!) and from the outside perspective of the user (youtube link!).
personally I am completely new to Arch Linux. Therefore please tell me with what commands I can install Xephyr within Fedora 32 or Debian 10. In order to screencast my Qube manager and my VMs with OBS-Studio.
Thank you.
Debian: the package is xserver-xephyr (install via sudo apt install xserver-xephyr)
Fedora: the package is xorg-x11-server-Xephyr (install via sudo dnf install xorg-x11-server-Xephyr)
Thank you for your help. I managed to install Xephyr successfully in Fedora 32. Also I achieved to execute Xephyr -br -ac -noreset -screen 800x600 :1 . However that was it. So far I don`t understand how to record my screen with OBS Studio and Xephyr. Please help me. Stay healthy & safe. Thank you.
Just to make sure we are on the same page, this will enable you to record what is happening in the black window started by running the Xephyr command. This window is a virtual screen or more properly a new virtual server. This won’t let you record the entire desktop.
To make things show up in this virtual screen, you have to prepend your commands with DISPLAY=:1 as explained in the Arch Wiki page. For instance, DISPLAY=:1 firefox should open Firefox in this virtual screen. You may also want to start a window manager in this screen first (see the wiki for an example as well).
If you run OBS in the same qube, there should be an option to select the screen/X server environment you want to share. You should be able to select :1 or something like that. At least it worked in the past. In the worst case, start OBS in the same screen. I think this is required for something like Zoom for instance (so DISPLAY=:1 zoom).
Let me know if you run into any roadblocks and we can work from there.
Is this truly the process for using OBS with Qubes? I have a Substack that’s about influence ops stuff, and it’s got a section called “Tool Time”, where I offer short videos showing how I do various tasks. That’s been done with OBS latching on to the output of a VM running Ubuntu Budgie that’s purpose built for those tasks.
This seems like one of those things that being secure will make really arduous.
It’s possible to use a static build of ffmpeg on dom0 for recording the screen
see Dom0 screen recorder for 4.1 - #12 by solene
That’s PERFECT.
A rather bloated executable, but knowing that works is about the last problem I need to solve.
Is there a history of people using AppImage in dom0?
just to be sure, I said ffmpeg is a static binary, it’s NOT an AppImage.
yes, I got that - a static image with all libraries included.
But is there a similar ability to use AppImage stuff? Those are also monolithic binaries.
AppImage should work on dom0, a commonly missing dependency for AppImages fuse which may not be installed on dom0 by default.
Good news, it seems obs-studio is now packaged for Fedora, and on Qubes OS 4.2, Fedora isn’t that old Unofficial Linux Builds · obsproject/obs-studio Wiki · GitHub
There is also this unofficial AppImage build of OBS Releases · ivan-hc/OBS-Studio-appimage · GitHub (not the same person doing the static ffmpeg build)
This is excellent news. The only barrier left for me shifting work is getting a solid Wireguard VPN template and something I can do OpenVPN with for that one provider that must have it.
I’ve been anticipating a Christmas bonus and cruising Ebay. Looks like a Dell Precision laptop with Xeon and 32GB is going to be just $300 - $400. Having a mobile device with Qubes will be a big goad towards getting me up to speed :slight_smile:
Does anyone have experience with qubes-video companion reagrding screencasting?
Would also be interested in this question as I still do not understand its use case.
I tried last year, the experience was worse than passing the webcam with sys-usb :woman_shrugging:
Hello, I just found this thread trying OBS on Qubes.
I installed OBS with FlaPak and works great out of the box: webcam+mic+screen recording.
The only thing that I does not seem to work is “Window Capture” (where only a single window is captured). When I add a `Window Capture (Xcomposite)", no windows appear in the list to choose from. That is, it looks like OBS can’t see the window of the appVM. However it can capture the screen very well.
Question: anybody managed to get OBS and its Window Capture functionality working in Qubes?
Edit: For a solution, see below.
I use qubes-video-companion to get my dom0 screen into the app VM running OBS and have my Nvidia GPU in there as well to do the encoding (following this guide).
Big issue for me, running this on a not-so-beefy CPU, is that the rendering (not the encoding) runs off the CPU entirely while this could be done by my GPU as well quite effortlessly. According to Claude, the rendering is done by OBS via OpenGL and thus handed off to llvmpipe on Qubes OS. It becomes an issue for me as the system-wide CPU usage hits 100% and the fps are still too low for my use case.
Any way to offload the rendering to my GPU?
Note: This is a testing machine, so security tradeoffs would be accepted.
A solution: I got this working; my CPU now sits nicely at around 10% in OBS, GPU mclk and wattage went up, by which I assume it does more stuff, and fps are fine now. Here is what I did on Debian 13 (Claude was used):
  1. Download .deb file from VirtualGL releases page and install using sudo dpkg -i filenamehere.deb
  2. sudo vglserver_config, choose the EGL option, answer “no” to the framebuffer access question
  3. echo 'export VGL_DISPLAY=egl' | sudo tee -a /etc/profile
  4. Restart VM.
  5. Run OBS (I installed it from the repo and not via Flatpak) with vglrun obs
Note on security: These five steps should not weaken security.
