Hi everybody!
Im have an issue on qubes 4., same issue I had with qubes 3.2
Imagine you have a laptop with touch screen. Like this one:
Everything works fine including touchscreen.
One day you decide to use it as a tablet. Good thing is that xfce configuration in dom0 allows you rotate screen(90 degrees). BUT user input remains the same with touchscreen and the same with the mouse.
Is there a way to change user input → shift it 90 degrees as well as the screen?
Or may be there is a guides on architecture of QubesOS input handling so I can develop some kind of work around?
Many thanks
