As stated in the documentation → Salt (management software) | Qubes OS
there are some Saltstack states already configured. Which states have come pre-configured? Could they
potentially have an effect on system security by having, for example, pre-configured telemetry?
Thank you
unman
June 26, 2022, 2:58pm
2
This depends on what options you selected at install.
Look at the relevant files in /srv/formulas/base/virtual-machines-forumla
Potentially there could be telemetry - you may judge for yourself.
There could equally be telemetry configured in templates. In Debian
there isn’t.
could telemetry be detected in the net-vm?
unman
June 30, 2022, 3:45pm
4
Using an IDS? Possibly
You would likely need to do some in depth traffic analysis, and it isn’t
going to be straight forward.
Are there any documentation or articles on pfSense being setup as a net-vm in order to run an IDS? I know
there is an article on setting up Mirage Qubes firewall.
