I have a bunch of salt states defined under /srv/user_salt/foo/init.sls and I’ve created the user_salt directory through the sudo qubesctl state.sls qubes.user-dirs command.
It has previously worked to run these states but a while back it stopped working and now when I try to run
sudo qubesctl foo saltenv=user
I end up getting
'foo' is not available.
DOM0 configuration failed, not continuing
Oddly enough running the locale state gives another output.
local:
locale:
'locale' is not available.
locale.avail:
Check if a locale is available.
New in version 2014.7.0
CLI Example:
salt '*' locale.avail 'en_US.UTF-8'
locale.gen_locale:
Generate a locale. Options:
:param locale: Any locale listed in /usr/share/i18n/locales or
/usr/share/i18n/SUPPORTED for Debian and Gentoo based distributions,
which require the charmap to be specified as part of the locale
when generating it.
verbose
Show extra warnings about errors that are normally ignored.
CLI Example:
salt '*' locale.gen_locale en_US.UTF-8
salt '*' locale.gen_locale 'en_IE.UTF-8 UTF-8' # Debian/Gentoo only
locale.get_locale:
Get the current system locale
CLI Example:
salt '*' locale.get_locale
locale.list_avail:
Lists available (compiled) locales
CLI Example:
salt '*' locale.list_avail
locale.set_locale:
Sets the current system locale
CLI Example:
salt '*' locale.set_locale 'en_US.UTF-8'
[ERROR ] An un-handled exception was caught by Salt's global exception handler:
KeyError: 'retcode'
File "/usr/bin/qubesctl", line 130, in <module>
salt_call()
File "/usr/lib/python3.11/site-packages/salt/scripts.py", line 443, in salt_call
client.run()
File "/usr/lib/python3.11/site-packages/salt/cli/call.py", line 50, in run
caller.run()
File "/usr/lib/python3.11/site-packages/salt/cli/caller.py", line 116, in run
sys.exit(ret["retcode"])
KeyError: 'retcode'
salt_call()
client.run()
caller.run()
KeyError: 'retcode'
I figured that it was running the locale state in my user_salt directory and tried to change the name of that directory, but it continued being able to run it, I changed the content of the init.sls file but it continued with the same output. So it seems like for some reason salt is not looking for states in my user_salt directory. I’ve tried looking for another locale file/directory that it might be finding when looking for that state, but haven’t found a plausible candidate.
Anyone know what is going on or know a way to debug this?
