I’m asking this mostly because it seems to defy the expected behavior based on what I’m reading.
The default fedora-39-minimal template does not ship with the qubes-mgmt-salt-vm-connector package, which appears to be required when running ANY qubesctl salt commands on the targeted template. I essentially see the following:
[root@dom0 srv]# qubesctl --skip-dom0 --targets=fedora-39-minimal --show-output grains.items
fedora-39-minimal:
_error:
Failed to return clean data
retcode:
1
stderr:
...deleted for brevity
[ERROR ] An un-handled exception was caught by Salt's global exception handler:
ModuleNotFoundError: No module named 'urllib3'
stdout:
However, installing qubes-mgmt-salt-vm-connector in a cloned template resolves the above.
management_dispvm are the same on both templates, so that’s not the problem.
[root@dom0 tmp]# qvm-prefs f39-m-test management_dispvm
default-mgmt-dvm
[root@dom0 tmp]# qvm-prefs fedora-39-minimal management_dispvm
default-mgmt-dvm
I don’t mind installing this package manually so I can use salt to target it, but how would any updates or anything be done on the default minimal template if it can’t even use salt out the box? Am I missing something?
