Here is how to reproduce the problem:
- Execute this to create user directories:
# qubesctl state.sls qubes.user-dirs
- Create file:
/srv/user_pillar/top.sls:
user:
- source
- depend
- Create file:
/srv/user_pillar/source.sls:
source:
value: 5
- Create file:
/srv/user_pillar/depend.sls:
{% import_yaml "source.sls" as source %}
depend:
value: {{ source['source']['value'] + 1 }}
- Create file:
/srv/user_salt/atest.sls:
{% set value = salt['pillar.get']('depend:value', 0) %}
message:
test.configurable_test_state:
- changes: False
- comment: 'value: "{{ value }}"'
- Execute the
atest.slsstate file:
# qubesctl --show-output state.sls atest saltenv=user
Here is the expected result:
local:
Function: test.configurable_test_state
Result: True
Comment: value: "6"
Started: 02:53:08.493550
Duration: 0.489 ms
Changes:
Summary for local
Succeeded: 1
Failed: 0
Total states run: 1
Total run time: 0.489 ms
Here is the actual result:
[ERROR ] Exception raised when processing __virtual__ function for salt.loaded.int.module.chroot. Module will not be loaded: 'path.which'
[WARNING ] salt.loaded.int.module.chroot.__virtual__() is wrongly returning `None`. It should either return `True`, `False` or a new name. If you're the developer of the module 'chroot', please fix this.
[ERROR ] Exception raised when processing __virtual__ function for salt.loaded.int.module.rebootmgr. Module will not be loaded: 'path.which'
[WARNING ] salt.loaded.int.module.rebootmgr.__virtual__() is wrongly returning `None`. It should either return `True`, `False` or a new name. If you're the developer of the module 'rebootmgr', please fix this.
[ERROR ] Exception raised when processing __virtual__ function for salt.loaded.int.module.rh_service. Module will not be loaded: 'systemd.booted'
[WARNING ] salt.loaded.int.module.rh_service.__virtual__() is wrongly returning `None`. It should either return `True`, `False` or a new name. If you're the developer of the module 'rh_service', please fix this.
[ERROR ] Exception raised when processing __virtual__ function for salt.loaded.int.module.transactional_update. Module will not be loaded: 'path.which'
[WARNING ] salt.loaded.int.module.transactional_update.__virtual__() is wrongly returning `None`. It should either return `True`, `False` or a new name. If you're the developer of the module 'transactional_update', please fix this.
[ERROR ] Exception raised when processing __virtual__ function for salt.loaded.int.module.win_timezone. Module will not be loaded: 'platform.is_windows'
[WARNING ] salt.loaded.int.module.win_timezone.__virtual__() is wrongly returning `None`. It should either return `True`, `False` or a new name. If you're the developer of the module 'win_timezone', please fix this.
[ERROR ] Rendering exception occurred
File "/usr/lib/python3.11/site-packages/salt/utils/templates.py", line 476, in render_jinja_tmpl
output = template.render(**decoded_context)
File "/usr/lib/python3.11/site-packages/jinja2/environment.py", line 1291, in render
self.environment.handle_exception()
File "/usr/lib/python3.11/site-packages/jinja2/environment.py", line 925, in handle_exception
raise rewrite_traceback_stack(source=source)
File "<template>", line 1, in top-level template code
File "/usr/lib/python3.11/site-packages/salt/utils/jinja.py", line 161, in get_source
self.check_cache(_template)
File "/usr/lib/python3.11/site-packages/salt/utils/jinja.py", line 115, in check_cache
ret = self.cache_file(template)
File "/usr/lib/python3.11/site-packages/salt/utils/jinja.py", line 107, in cache_file
fcl = self.file_client()
File "/usr/lib/python3.11/site-packages/salt/utils/jinja.py", line 96, in file_client
self._file_client = salt.fileclient.get_file_client(
File "/usr/lib/python3.11/site-packages/salt/fileclient.py", line 60, in get_file_client
return {"remote": RemoteClient, "local": FSClient, "pillar": PillarClient}.get(
File "/usr/lib/python3.11/site-packages/salt/fileclient.py", line 92, in __init__
self.utils = salt.loader.utils(self.opts)
File "/usr/lib/python3.11/site-packages/salt/loader/__init__.py", line 536, in utils
return LazyLoader(
File "/usr/lib/python3.11/site-packages/salt/loader/lazy.py", line 262, in __init__
opts = copy.deepcopy(opts)
File "/usr/lib64/python3.11/copy.py", line 146, in deepcopy
y = copier(x, memo)
File "/usr/lib64/python3.11/copy.py", line 231, in _deepcopy_dict
y[deepcopy(key, memo)] = deepcopy(value, memo)
File "/usr/lib64/python3.11/copy.py", line 153, in deepcopy
y = copier(memo)
File "/usr/lib/python3.11/site-packages/salt/utils/context.py", line 234, in __deepcopy__
copy.deepcopy(self.__dict, memo), copy.deepcopy(self.pre_keys, memo)
y = copier(memo)
File "/usr/lib/python3.11/site-packages/salt/utils/context.py", line 139, in __deepcopy__
new_obj.global_data = copy.deepcopy(self.global_data, memo)
y = copier(x, memo)
y = copier(x, memo)
File "/usr/lib64/python3.11/copy.py", line 172, in deepcopy
y = _reconstruct(x, memo, *rv)
File "/usr/lib64/python3.11/copy.py", line 271, in _reconstruct
state = deepcopy(state, memo)
y = copier(x, memo)
y = copier(x, memo)
y = copier(x, memo)
y = copier(x, memo)
File "/usr/lib64/python3.11/copy.py", line 161, in deepcopy
rv = reductor(4)
TypeError: cannot pickle '_thread.RLock' object
During handling of the above exception, another exception occurred:
File "/usr/lib/python3.11/site-packages/salt/utils/templates.py", line 218, in render_tmpl
output = render_str(tmplstr, context, tmplpath)
File "/usr/lib/python3.11/site-packages/salt/utils/templates.py", line 522, in render_jinja_tmpl
raise SaltRenderError(
salt.exceptions.SaltRenderError: Jinja error: cannot pickle '_thread.RLock' object
return LazyLoader(
y = copier(x, memo)
y = copier(memo)
y = copier(memo)
y = copier(x, memo)
y = copier(x, memo)
y = copier(x, memo)
y = copier(x, memo)
y = copier(x, memo)
y = copier(x, memo)
rv = reductor(4)
; line 1
{% import_yaml "source.sls" as source %} <======================
depend:
[CRITICAL] Rendering SLS 'depend' failed, render error:
File "/usr/lib/python3.11/site-packages/salt/pillar/__init__.py", line 938, in render_pstate
state = compile_template(
File "/usr/lib/python3.11/site-packages/salt/template.py", line 99, in compile_template
ret = render(input_data, saltenv, sls, **render_kwargs)
File "/usr/lib/python3.11/site-packages/salt/loader/lazy.py", line 159, in __call__
ret = self.loader.run(run_func, *args, **kwargs)
File "/usr/lib/python3.11/site-packages/salt/loader/lazy.py", line 1245, in run
return self._last_context.run(self._run_as, _func_or_method, *args, **kwargs)
File "/usr/lib/python3.11/site-packages/salt/loader/lazy.py", line 1260, in _run_as
return _func_or_method(*args, **kwargs)
File "/usr/lib/python3.11/site-packages/salt/renderers/jinja.py", line 62, in render
tmp_data = salt.utils.templates.JINJA(
return LazyLoader(
y = copier(x, memo)
y = copier(memo)
y = copier(memo)
y = copier(x, memo)
y = copier(x, memo)
y = copier(x, memo)
y = copier(x, memo)
y = copier(x, memo)
y = copier(x, memo)
rv = reductor(4)
; line 1
depend:
[CRITICAL] Pillar render error: Rendering SLS 'depend' failed. Please see master log for details.
local:
Data failed to compile:
Pillar failed to render with the following messages:
DOM0 configuration failed, not continuing
Here is the system setup:
- Qubes OS version: 4.2
- Python version: 3.11.6-1.fc37
- Packages:
$ sudo dnf -C list installed | grep salt
qubes-mgmt-salt.noarch 4.2.2-1.fc37 @qubes-dom0-cached
qubes-mgmt-salt-admin-tools.noarch 4.2.2-1.fc37 @qubes-dom0-cached
qubes-mgmt-salt-base.noarch 4.1.7-1.fc37 @qubes-dom0-cached
qubes-mgmt-salt-base-config.noarch 4.1.2-1.fc37 @qubes-dom0-cached
qubes-mgmt-salt-base-topd.noarch 4.2.1-1.fc37 @qubes-dom0-cached
qubes-mgmt-salt-config.noarch 4.2.2-1.fc37 @qubes-dom0-cached
qubes-mgmt-salt-dom0.noarch 4.2.2-1.fc37 @qubes-dom0-cached
qubes-mgmt-salt-dom0-qvm.noarch 4.2.1-1.fc37 @qubes-dom0-cached
qubes-mgmt-salt-dom0-update.noarch 4.1.14-1.fc37 @qubes-dom0-cached
qubes-mgmt-salt-dom0-virtual-machines.noarch 4.2.14-1.fc37 @qubes-dom0-cached
salt.noarch 3006.5-1.fc37 @qubes-dom0-cached
salt-minion.noarch 3006.5-1.fc37 @qubes-dom0-cached
I also tested in an ArchLinux standalone HVM using plain salt-call --local. It worked.
Here is the Arch Linux system setup:
- Arch Linux install version: 2024.07.01
- Salt version: 3007.0-2
- Python version: 3.12.4-1
I also tested in a Fedora 39 dispvm. It worked.
Here is the Fedora 39 dispvm setup:
- Packages:
qubes-mgmt-salt-vm-connector.noarch 4.2.2-1.fc39 @qubes-vm-r4.2-current
salt.noarch 3006.8-1.fc39 @updates
salt-minion.noarch 3006.8-1.fc39 @updates
salt-ssh.noarch 3006.8-1.fc39 @updates
- Python version: 3.12.3-2.fc39
Question:
- How can I make
import_yamlwork in Qubes OS? - Is this an upstream problem that might get fixed when Qubes OS upgrades?
