I’m writing a simple script to replicate Qubes Update’s “Restart all system qubes after update” functionality
Essentially (pseudocode):
for each sys-* qube except sys-usb ; do
if { qvm-check -q --running "$qube" } and
{ qvm-volume info "${qube}":root is_outdated } = 'True'
then
qvm-shutdown --force --wait "$qube"
qvm-start "$qube"
fi
done
(a quite dumb version of what Qubes Update does, based on a scan of the source.)
On one hand I think this is fine- everything will reconnect back up. On the other hand I’m a little leery because Qube Manager won’t let me shutdown system qubes unless I also shutdown connected qubes (which I don’t want to do), and there may be good reasons for that.
Can I understand Qube Manager’s safety check here to just be a protective for new users? Or is there something inadvisable in restarting system qubes without shutting down connected qubes?
