Can I load qubes os on an encrypted usb stick? iStorage diskAshur Pro2 SSD 128GB or datashur pro 2, will make it safer and best or does it make no difference to a normal usb stick?
Hi @Leonkarr22, welcome to the Community!
You can install Qubes OS on an external USB stick or SSD. The problem with you question is you didn’t say against what threats your want to be protected. Depending on that, the USB stick installation could make you safer or less safe. See this: Threat model - Wikipedia.
