has someone managed to run IncludeOS on qubes?
I tried to mount the image as cdrom but it won’t boot.
The trick with adding it as a kernel like for the mirage-firewall doesn’t work either.
The vm ends up in “no bootable device found”.
The image runs on virtmanager on a ubuntu system with xen.
IncludeOS can be setup as firewall.
I would like to replace current sys-firewall with it to make the qubes system faster.
If you use a “standard” configuration, then it is very easy to use to install and use. If you need special configuration of the firewall, then you must edit the rules and complile: not for me :).
Maybe you can “mimic” the installation process and suceed to install IncludeOS?
I tried to mimik the installation of mirage-firewall.
And I tried also the steps found in the readme file of qubes-builder-mirage
Nothing worked for me.
With Q 4.1 I created a new qube vm, stamdalone with img files in var/lib/qubes. Then replaced the root image with a image where IncludeOS is installed.
The vm is booting, but not loading IncludeOS.
And after some seconds the vm is halted because of the missing qrexec connection.
I tried to set the feature gui and qrexec to an empty string but I could not turn of this automatic shutdown of the vm.
Could you be absolutely clear what you mean by “run IncludeOS on qubes”
and “an image where IncludeOS is installed”?
If you want to use an IncludeOS application as a qube (and I think this is
what you are saying) then this seems to be a nonstarter. Afaik an
IncludeOS application on Linux requires some dependencies that you wont
be able to install in dom0 - like qemu.
It’s quite possible that I’m talking nonsense but if you could be a little
clearer about what you want to do, and perhaps provide a concrete example,
I could be clearer too.
Specifically which Image are you trying to run?
IncludeOS is a minimal unikernel for C++ services.
I used a demo examples called router service and compiled it and created a bootable image.
So I am trying to get this image unikernel to run in a qube vm.
I am developing the unikernel on ubuntu 20.04.
Here he steps I did now in details to get the image: #1 setup Includeos
Thanks, I know what IncludeOS provides and have deployed applications
myself.
I was not able to run them under Linux without using qemu, and
that is a non-starter in Qubes, as I explained. Things may have changed.
I’m intrigued by your suggestion:
Can you tell me what commands you used to do this, and what packages
you installed on the Ubuntu system?
Virt Manager still used qemu instead of xen.
That is why it was working.
I have problems to setup virt Manager to work with xen. I am trying to solve this.
I will give an update when I fixed this.
By the way is it possible to use virt Manager beside qube manager in QubeOS?
For developing/testing it would be interesting to have an alternative.
OK, I see nothing to suggest that IncludeOS can be run without qemu, and
you cant install qemu without breaking Qubes, so this really is a non
starter imo.
Happy for you to prove me wrong.
I got to run the IncludeOS sample to run on xen.
There is no change needed.
The problem is that the vga driver is not included in some examples like hello_world.
Because Include OS can run on a normal hardware, ut runs in Xen in a hvm vm.
On Ubuntu 20.04 I have installed xen and connected me to it with Virt Manager.
The image file I attach as a harddrive disk.
I added an serial port device which writes to a file.
There I can see that it has started successfully.
On Qubes (4.1) I can start now Include OS in the same way as I do in Ubuntu.
But I guess qrexec is shutting down the vm after I have started it.
I have tried to use qvm-features Incl1 qrexec -D but it is still getting killed.
Do you have an idea what I can try to prevent qubes from killing the vm?
Unfortunately the project IncludeOS is not maintained anymore.
Therefore I have to look for an alternative.
I know there is Mirageos but I look for a unikernel project where I can write code in C or C++
