After several months of learning Qubes, I realized that the ethernet sys-net (not to say wifi) is the weakest link in Qubes, only to find out that it was already been discussed here, which proves what I concluded:
I decided to start a new topic due to its visibility and the idea I got, but please merge it with above if you find it more appropriate.
Now, after thinking through and reading a lot, these are the facts:
Ethernet is safer than internal or external wifi.
Ethernet sys-net has to be ran in HVM mode and thus it’s attack surface is significant.
Internal wifi has to be ran in HVM mode plus radio range, which make its attack surface bigger than ethernet’s.
External wifi could be ran in PVH mode, by attaching it to sys-net-ext-wifi via sys-usb, This equation for attack surface would be:
PVH - (radio range + bad USB)
for which I am not sure if its attack surface is bigger than for internal wifi, so
please share your thoughts on this.
Thinking on this, I thought maybe the smallest attack surface would be for the equation
- PVH - radio range + bad USB
which led me to the topic title and to this:
I tried this. I have created disposable sys-usb-to-RJ45-adapter , then I created disposable sys-net-to-RJ45-adapter running in PVH mode, attached ethernet cable from the router to it, and it works flawlessly.
Now, I am absolutely aware that I am not that smart to be the first to realize that this is maybe the safest option for our sys-net, but please let me know why and is running ethernet in HVM mode safer than running ethernet in PVH mode with taking the risk of a bad USB adapter firmware handled by correspondent sys-usb.
