I am attempting to run the intrusion detection program AIDE in dom0, but I seem to be getting the flowing errors when running “sudo aide --check”
“md_enable: algorithm 7 not avialable” “gcry_md_enable 7 failed Couldn’t open file/var/lib/aide/aide.db.gz for reading”
I can’t comment on this particular issue. But I would take a step back and re-evaluate why you think an IDS in dom0 is needed. I’ve just created a separate discussion for this this very topic, if you’re interested:
