Vault qube w/ Credentials RPC service (credentials-vault)
dom0 / policy-qube/-vm
service.Credentials policy
Using latest/current/newer policy-format/-location:
<<'EOF' cat | >/dev/null sudo tee /etc/qubes/policy.d/30-user-service-Credentials.policy
# service , arg , source , target , action-params .
service.Credentials +PassInput @anyvm @anyvm allow target=credentials-vault
service.Credentials +SockInput @anyvm @anyvm allow target=credentials-vault
EOF
credentials-vault
service name-/argument-based “proxy”
requires notify-send
might require socat
<<'EOF' cat | >/dev/null sudo tee /etc/qubes-rpc/service.Credentials
#!/bin/sh
# callable from vm's that need cleartext credentials
# required clear-text-credentials-service-name
credentialsSubject="${1?}"
: # "safeguard" - Send notification bubble (from VM) for each request
vaultName="$( qubesdb-read /name )"
from="${QREXEC_REMOTE_DOMAIN?}"
notify-send "[${vaultName?}] Credentials request from: ${from?}"
unset vaultName
unset from
if test "is${credentialsSubject?}" == "isPassInput"
then
: # callable through: qrexec-client-vm wrk-b-vault service.Credentials+PassInput
/home/user/output_credentials.sh
elif test "is" == "isSockInput"
then
: # callable through: qrexec-client-vm wrk-b-vault service.Credentials+SockInput
socat - 'UNIX-CONNECT:/home/user/creds.sock'
# socket could be created with:
# socat 'UNIX-LISTEN:/home/user/creds.sock,fork' 'EXEC: printf "credential\nstuff" '
# socat 'UNIX-LISTEN:/home/user/creds.sock,fork' 'EXEC: /home/user/output_credentials.sh '
fi
EOF
service example totp
requires oathtool, zenity
<<'EOF' cat | >/dev/null sudo tee /home/user/output_credentials.sh
# asking for seed befor password, because
# return is pipe (`|`) separated & seed should be free of that character .
seed="$(
DISPLAY=:0 zenity \
--title "One Time Password Seed" \
--text "Token" \
--entry \
timeBasedOneTimePassword="$( oathtool --totp --base32 "${seed?}" )"
unset seed
printf '%s' "${timeBasedOneTimePassword?}"
unset timeBasedOneTimePassword
service example password + totp
input="$(
DISPLAY=:0 zenity --forms \
--title "Creds" \
--text "Input Credentials" \
--add-entry "One Time Password Seed" \
--add-entry "Password" \
seed="${input%%|*}"
password="${input#*|}"
unset input
#>&2 printf "Password: %s\nTime Based One Time Password (TOTP): %s\nSeed used for TOTP: %s" "${password?}" "${timeBasedOneTimePassword?}" "${seed?}"
unset seed
printf '%s%s' "${password?}" "${timeBasedOneTimePassword?}"
unset password
requirements check/set
#aka trusted software/externals
cmds_install='sudo apt install --yes'
# debian
cmds_install='sudo dnf install --assume-yes'
# fedora
${cmds_install?} \
oathtool \
socat \
zenity \
# debian & fedora package names are the same #afaik
# package names listed on new lines to allow for vim to :'<,'>sort
>/dev/null 2>&1 type notify-send ||
>&2 prinf 'Missing required notify-send.'
exit 1
