Route all Traffic through tor (no clearnet traffic)
How can i route all Qubes OS traffic through tor (sys-whonix) and block all clear-net traffic?
Use sys-whonix as netvm instead of your standard net-vm.
There’s been discussion of this before in the Forum.
You will also want to disable services on sys-net and sys-firewall that
will run in the clear.
disable qubes-update-check in these two qubes, clock-sync. Change the
updatevm from sys-firewall.
You can cover the bases also by blocking all outbound traffic from
these qubes using nftables.
