i’m trying to create a lab with kioptrix level 1. converted to raw as the documentation said and created qube same [based on documentation]
I added 4 GB to the qube and 2 CPU and tried both with “include in max memory” enabled [with 6gb] and without it but it will not boot.
I’m stuck at Kernel panic: No init found. Try passing init= option to kernel.
The only thing from logs that is not looking good is this one qemu: pin_memory_cacheattr failed: Operation not permitted and from what I saw people are saying that maxmem should not be 0 but I changed that as well with qvm-prefts [same as from UI above] and still same error.
Any ideas?
