I got polkit-gnome for F38 but that didnt fix it. There is no polkit for XFCE4.
Protonvpn-cli also wont connect. Suggestions?
@procShield there is nothing Qubes OS specific in your question, which is therefore off-topic in this forum. But you have reached trust level 2 and have access to our âAll Around Qubesâ category. This category is for Qubes OS related (but not specific) questions like yours. I moved the thread there.
Installing polkit-1-gnome (on Debian11) solves the canât find agent error message but VPN still does not connect. There is no polkit equivalent in F38.
Latest error message is /sbin/iptables , -t nat flush -PR-QBS None. Previously, I just had to follow the directions of the respective VPN for which OS and it would work. No iptables configuration. Did something change?
Qubes 4.2 dropped support for iptables. This may be the reason why youâre seeing this error.
Thanks. So I need to configure ip/nftables.
[protonvpn cli also no longer works on R4.2 so information on iptables configuration is needed]
nm-lib exceptions api session is not valid invalid refresh token
Iâm not sure how this app works, but if you can turn off the in-app firewall then I think you can create your own custom rules using nftables.
For reference, the firewall doc is not updated yet for the change. A pull request was created to replace everything with nftables:
Honestly, RiseUp VPN never worked properly for me regardless of which OS I use /shrug
Worked for me up to quebesos 4.2 after the deb packages were updated per first link in previous post. From my understanding, all is missing is nftables support.
Werenât they deprecating the .deb package in favor of the snap one? But yeah I did try to use them awhile back and it couldnât even install because it was so outdated
RiseUp doesnât work for me either. Iâve been testing various VPN softwares, I donât know if itâs because AppVM has a volatile root. Or because of a connection problem. Iâve already tried openvpn too, and it doesnât let me, I donât really think itâs my connection problem, because I can still use extensions and thatâs what Iâve been using so far (mozilla addons). Iâd like to know if they find a solution to my problem, because I donât really understand this very much, Iâm a bit inexperienced and I find it kind of annoying to have to use extensions because they say firefox is not very secure.
