PC was off for a few Months, i do make backups but not 100% sure if anything of importance is in the home folder and not already backed up.
AppVM Starts
Applications do not start though.
qvm-run -a personal xterm Running 'xterm' on personal
nothing happens, no prompt, just hangs there untill i hit ctrl+c
Fedora 32 (Thirty Two)
Kernel 4.19.142-1.pvops.qubes.x86_64 on an x86_64 (hvc0)
localhost login: [ 11.821673] kauditd_printk_skb: 39 callbacks suppressed
[ 11.821676] audit: type=1106 audit(1600260187.712:53): pid=1290 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_keyinit,pam_limits,pam_systemd,pam_unix,pam_umask,pam_lastlog acct="user" exe="/usr/bin/qubes-gui-runuser" hostname=localhost addr=? terminal=/dev/tty7 res=success'
[ 11.821853] audit: type=1104 audit(1600260187.712:54): pid=1290 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_rootok acct="user" exe="/usr/bin/qubes-gui-runuser" hostname=localhost addr=? terminal=/dev/tty7 res=success'
[ 21.932952] audit: type=1131 audit(1600260197.823:55): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 21.961386] audit: type=1131 audit(1600260197.851:56): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 28.650823] audit: type=1100 audit(1600260204.541:57): pid=1575 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_rootok acct="user" exe="/usr/lib/qubes/qrexec-agent" hostname=? addr=? terminal=? res=success'
[ 28.651938] audit: type=1103 audit(1600260204.542:58): pid=1575 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_rootok acct="user" exe="/usr/lib/qubes/qrexec-agent" hostname=? addr=? terminal=? res=success'
[ 28.681775] audit: type=1130 audit(1600260204.572:59): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 28.693159] audit: type=1101 audit(1600260204.583:60): pid=1578 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_unix acct="user" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 28.693198] audit: type=1103 audit(1600260204.583:61): pid=1578 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="user" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 28.693289] audit: type=1006 audit(1600260204.583:62): pid=1578 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[ 28.697310] audit: type=1105 audit(1600260204.587:63): pid=1578 uid=0 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_selinux,pam_selinux,pam_loginuid,pam_keyinit,pam_limits,pam_systemd,pam_unix acct="user" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 28.804843] audit: type=1130 audit(1600260204.695:64): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 28.812056] audit: type=1105 audit(1600260204.702:65): pid=1575 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_open grantors=pam_keyinit,pam_limits,pam_systemd,pam_unix,pam_umask,pam_lastlog acct="user" exe="/usr/lib/qubes/qrexec-agent" hostname=? addr=? terminal=? res=success'
PS
not able to post full log due to forum limitation
