I know how to restrict a clearnet qube to a specific host (through “Settings” tab or through qvm-firewall). I also understand that Whonix works through Tor proxy which itself requires connections to the Tor guard to work, so simply restricting a whonix-based qube “the clearnet way” would not work.
So, what is the correct way to restrict access of a whonix-based qube to specific host(s)?
You should be able to put a firewall qube between the whonix gateway and its clients. Then just use qvm-firewall as usual on the respective client qube you want to restrict.
Possibly there’s already a firewall qube in fron of the whonix hosts by default - I haven’t used it in a while.
