Although restoring R3.2 AppVMs to R4.0 generally works with no problem, there are additional steps that need to be performed when doing the same with Templates and Standalone VMs. If these steps are not done, the result is an inability to start programs from the Qubes menu for the restored VM.
- After restoring your Template or StandaloneVM, go to Qube Settings → Basic tab. Confirm Networking is set to one valid for your R4.0 system. Then, under the Advanced tab, confirm Virtualization Mode is
PVH, and that Kernel is set todefault. - From a dom0 prompt, enter
qvm-run <templatename> gnome-terminal(orxtermifgnome-terminalis not installed). - Once the terminal window comes up, open another terminal window to a known good R4.0 template.
- From the known good template’s terminal,
qvm-copy /etc/yum.repos.d/qubes-r4.repoto the restored template. - Do the same with
qvm-copy /etc/pki/rpm-gpg/RPM-GPG-KEY-qubes-4-*. - On the restored template’s terminal,
cdinto theQubesIncomingsubfolder that contains the files you copied over from the known good R4.0 template, then insumode:
cp qubes-r4.repo /etc/yum.repos.d/
rm /etc/yum.repos.d/qubes-r3.repo
rpm --import RPM-GPG-KEY-qubes-4-*
dnf update
## You will receive an error about qubes-core-agent transaction failed, so continue with:
dnf install qubes-core-agent qubes-kernel-vm-support
systemctl enable qubes-gui-agent
poweroff
You should then be able to use your restored Template’s shortcuts as normal.
- Page archive
- First commit: 17 Jun 2018. Last commit: 17 Jun 2018.
- Applicable Qubes OS releases based on commit dates and supported releases: 3.2, 4.0
- Original author(s) (GitHub usernames): awokd
- Original author(s) (forum usernames): N/A
- Document license: CC BY 4.0
