off-topic banter
If you’re not joking, then you’re severely naive at how things run outside your little cloister.
Tell this nonsense to 2 of my colleagues who are dead. Tell it to my other colleague who was wrongfully committed to an insane asylum, and kept pumped up with drugs to keep him silent.
And for someone you might even be able to relate to, tell that to Assange.
Like most good obedient slaves, you’re severely ignorant to how the world runs. Try traveling a bit. Try stepping outside those lines painted for you by the good old USSA. Try working on anything beneficial to humanity, that directly confronts the cartels that run this prison planet.
If you have something useful to offer the problem at hand, I’m all ears, and I do appreciate it. If you have another string of derogatory comments, well… in the words of a mentor of mine, “you can go $%^& ______”.
Re: Security and privacy.
No, I hate this shit. I hate having to dedicate so much hashing power for this shit, that in the end does not create anything of value. It only prevents the destruction of value.
I would love to leave this shit up to other people, and instead focus on creation. But in this dystopian world you seem to be completely naive to, we don’t have that luxury.
Re: network
This was the string. All qubes connect to the firewall via sys-net first:
sys-net → sys-firewall → sys-vpn1 → sys-vpn1 → sys-whonix
And for that particular application it gave the other side the perception exactly what I was looking for. And if it hadn’t we wouldn’t be talking now.
Re: dom0 update. I cannot rule it out. But whenever I update I’m fastidious about noting it down, rebooting, and checking the hashes when the updates are done. It was a long computing session thru the night. I can’t rule out that I just missed something in a tired state. That’s the only vector I can imagine unless there was some zero-day that could break the vm sandbox.
Re: A bad update:
No, qubes were taken down in a coordinated attack. Likely Flatpak was the security hole.
Re: Security hold: Security hole (but you knew that).
Cheers
