Hello,
I am running latest QubesOS 4.2 from fresh install.
I would like to create a wallet-dvm Template from Template fedora-38
To do so, I copy the same settings as default-dvm (Type: AppVM with Advanced > Disposable template).
In the wallet-dvm Template I want to install Firefox wallet (Metamask, etc…) plugins.
Then I want to run disposable APPS (Qubes 4.2 menu) from wallet-dvm with fresh install of the wallet.
However copying default-dvm and whonix-workstation-17-dvm settings to create my template wallet-dvm, the behavior or disp apps differs.
My template crypto-dvm shows in both APPS and Templates (4.2 menu) but the icon is one unique cube. While default-dvm shows 2 cubes icon.
If I start a dvm app in APPS with default-dvm it actually start a disposable while if I start my APPS wallet-dvm, it seems to simply start the Template.
I can’t find the instruction to replicate the default-dvm behavior (one template and then to be able to run several disposable app on this template). And to finally have the same icon (2 cubes) so I can run 10 disposable wallet-dvm on my template wallet-dvm with fresh plugin wallet installed.
Any support or links are welcome!
Thank you,
