whoami
November 27, 2022, 10:55am
1
I try to make a new USB Qube (usb-dvm ) based on a Debian minimal disposable template.
I have the following error:
Package which has been installed:
qubes-usb-proxy
qubes-input-proxy-sender
qubes-core-agent-nautilus
nautilus
zenity
policykit-1
libblockdev-crypto2
exfat-fuse
exfat-utils
ntfs-3g
eject
Templates and AppVM configuration:
# ${1} "standard" templateVM name (deb-xx-m-usb)
# ${2} disposable templateVM name (deb-xx-m-usb-dvm)
# ${3} disposable serviceVM name (usb-dvm)
# ${4} label (red)
# create disposable templateVM (based on the "standard" templateVM)
qvm-create ${2} --template ${1} --label gray
# configure template as disposableVM
qvm-prefs ${2} autostart false
qvm-prefs ${2} netvm ''
qvm-prefs ${2} template_for_dispvms true
qvm-prefs ${2} default_dispvm ${2}
qvm-prefs ${2} virt_mode pvh
# create disposable serviceVM
qvm-create ${3} --class DispVM --template ${2} --label ${4} --property virt_mode=hvm --property provides_network=true --property netvm="" --property autostart=true
# attach pci
USB="dom0:00_14.0"
qvm-pci attach --persistent usb-dvm ${USB}
PS: My old sys-usb is still listed as backup but I unchecked Start qube automatically on boot . I also used it to verify my USB device (PCI settings).
You need to add the no strict reset flag:
$ qvm-pci detach -v sys-usb dom0:00_14.0
$ qvm-pci attach -v --persistent --option no-strict-reset=True sys-usb dom0:00_14.0
enmus
November 27, 2022, 9:05pm
3
Or, if that doesn’t work to set the qube in virt_mode pv
whoami
November 29, 2022, 8:51am
4
Thanks @BEBF738VD your proposal worked for me.
Just one correction, you mean (in my case) network-dvm instead of sys-usb here:
My usb-dvm is working fine, but now my keyboard and mouse is still blocked. Previously, this one-liner did the job (for sys-usb):
sudo qubesctl state.sls qvm.usb-keyboard
But I guess, this works only for a usb qube which is named sys-net .
Now, I wonder which policies do I need to update:
The keyboard and mouse policies in /etc/qubes-rpc/policy/ are obsolete and I cannot find the corresponding file or line in /etc/qubes/policy.d/ directory.
The old policy format will still be supported until at least Qubes 5.0.
So you should be fine just updating those.
Did you mean sys-usb?
You can change the value of the following in /srv/formulas/base/virtual-machines-formula/qvm/usb-keyboard.sls:
include:
- qvm: sys-usb
Or just remove those two lines entirely (since that’ll require another state)
Then in the same file you’ll have to replace 'sys-usb' accordingly.
whoami
November 29, 2022, 9:04am
7
BEBF738VD:
Did you mean sys-usb ?
yeah, sorry typo. Correct, I meant sys-usb .
I cannot find this file. My directory ends here /srv/formulas/ I do not have a base folder.
You need to be root. Run sudo -i before.
whoami
November 29, 2022, 9:25am
9
I got an error message…
So, I decided to redo the modifications manually on the obsolete /etc/qubes-rpc/policy/ files. This works, now.
Thanks for your support!
Now, I can check:
network- dvm
firewall-dvm
usb-dvm
all automatally created via a Debian minimal script.
Next, on my list
No worries. Out of curiosity, why this whole effort? Wouldn’t it be easier to create dvm templates and use those for sys vms?
whoami
November 29, 2022, 9:54am
11
I want to have a minimal template for each Qube (= Application).
My network-dvm requires i.e. qubes-core-agent-networking, qubes-core-agent-network-manager, firmware-iwlwifi, gnome-keyring whereas my usb-dvm requires qubes-usb-proxy, qubes-input-proxy-sender, exfat… ntfs… eject …
Some of my major to dos are still:
apt-cacher (auto setup and auto-vm configuration)
audio-dvm
Currently, it looks like this:
What I was saying is, instead of replacing (for example) sys-usb with usb-dvm, why not just replace the template?
Less of a hassle I’d think, especially with policies. Then again, it was just curiosity so you do what works best for you!
