So I found a few dated posts (2021) related to multi monitor and rdp but no resolutions so I thought I’d ask to see if perhaps anything has changed or anyone has figure this out since.
So for work I have to use Win11 and I have a dedicated notebook for it, and fortunately they allow me to set up RDP so I have successfully used my noteboook via Remmina’s RDP for awhile now but it really bugs me that i can’t use my multi monitor setup as that best matches my work (and play) flow. I have confirmed that Remmina does support Multimonitors and I noticed many of the posts were talking about “full screen” which, if they were talking about not showing anything from qubes (no menu etc) that i dont’ care about - actually don’t want it - but I would really like to be able to move some of my window windows to another screen as i have a portrait–landscape–portrait/PLP) monitor setup. I know my setup is niche but if there is anyone who has solved this, or knows how to I would so really appreciate some guidance.
So I am not entirely sure what you are asking for but all i can say is that i run qubes with the same monitor setup as you (PLP). I can (I don’t use that particular feature now as i find it more convenient to keep the monitors separate), and i have just checked now, because I haven’t used it with this particular version of qubes, configure the screen so all 3 monitors act as one screen (although the screen should be a perfect rectangle so the plp setup is not perfect but still usable). So if i now press alt + F11 firefox will stretch across all the 3 monitors.
Now if that is what you want let me know and i will try and explain how i did it, i think its pretty simple but I tried to explain it to another person on the list a year or so back and i don’t think i did a good job of explaining it.
Anyway its late here so i am off to bed so it might be a few hours before i get back to you.
Hi thank you for the response! So I have narrowed it down a bit, I can get it going the way i want (kind of) using xfreerdp, albeit flakey, so that makes me think its Remmina because when i “enable multi monitor” i get only one monitor and screen tearing and really slow, when i disable (untick) the enable multmonitor and enable force multimonitor i get… still one monitor but not slow or screen tearing. I really like Remmina so if possible I’d like to continue using that, it wasnt clear to me if you used Remmina or something else but it i can get multi-mon working then i will def change to another (stable) program. I will be interested to hear how you got yours going.
btw, i tried using flatpak run com.freerdp.FreeRDP /v:192.168.X.X /u:hh /multimon and while i still got a window to input host and passwd it did work, but the rendering had windows start buttons like in 4 different places on 3 screens and… well it wasnt usable, and then it crashed (or i pressed some key combo it didn’t like, I haven’t figured out which yet)
I don’t use remote desktop, the above “solution” only makes xorg see 3 monitors as one giant monitor so every app is then only aware of one really big monitor. I am assuming that you would use Remmina in a Qubes App vm and you would then rdp to a windows box? If that is the case, then Remmina, instead of seeing 3 27" monitors would actually see one 56" (or whatever) monitor. I would assume you would then need to configure the windows box to a 56" (or whatever) display, but then you would not need to use multimon. Now of course i have not tried rdp so i am not 100% sure it will work in the exact way in that particular setup even in theory it should, so if you find an alternative solution then great. With the 1 screen solution and the setup we use (plp) there is always a dead part of the screen because its not a perfect rectangle but as long as the dead part in windows it top middle then is should not be a problem because the apps can be manually positioned to fit the screen. Like i say its a possible solution and maybe the perfect solution for some, but also not the perfect for others also.
