The “Advanced” tab of the “Qubes Manager” has a tick for “Disposable VM template” —> good
In the Q Menu, there is the prefix “Disposable:” before “test-dvm” —> good
Starting xterm or thunderbird or firefox-esr from the Q menu starts a dispXXXX —> Great
Starting Files (nautilus) from the Q menu starts test-dvm —> bad
1. How to have all the applications from the Q menu starting in a dispXXXX (including e.g. Files/Nautilus)?
More importantly:
I have another VM (let’s call it other-dvm) that I would like to use as a template for dispXXXX.
In the Q menu, it is listed as: “Domain: other-dvm” and typing qvm-features other-dvm appmenus-dispvm 1 (in dom0) does not change anything, i.e. it is still listed as “Domain: other-dvm” and not as “Disposable: other-dvm” in the Q menu. NB: No error is thrown when typing the command.
Starting every app from the Q menu (e.g. xterm) starts other-dvm. Expected result: a dispXXXX is started
In dom0, qvm-prefs other-dvm displays (among others): template_for_dispvms - True
2. How can I turn that other-dvm VM into a template for disposable VMs? Meaning, how can I have all applications started from the Q menu to be started into a dispXXX
Thank you for your help and suggestions for these 2 questions.
I suppose the issue with your other-dvm as well as the ‘Files’ shortcut
of your test-dvm is that these shortcuts already existed before you
set the template_for_dispvm property and enabled the appmenus-dispvm
feature.
Could you go to your Qube Settings | Applications tab … remove all
shortcuts. Close/reopen the dialog and re-add the shortcuts you want?
Maybe that helps.
@Sven : Slightly faster is to use Apply, and then re-add.
Also note that once you Apply or Close, there is a behind the scene process that runs which needs time to complete its work… Which, it oftentimes seems not to - i.e., fails silently.
For example, there are recurring problems with “Run Terminal” and XFCE Terminal…
These have so far been only at the “annoyance” level, with the workaround being to keep banging at it until it works. So, since I’m not changing the Menu shortcuts that often, I haven’t tried to create a rigorous test case for a bug report…
Ups. This might be due to the process @QubicRoot mentioned. My PR
currently proposes this text:
Note: application shortcuts that existed before setting this feature
will not be updated automatically. Please go the the “Applications” tab
in the qube’s “Settings” dialog and unselect all existing shortcuts by
clicking “<<”, then click “OK” and close the dialog. Give it a few
seconds time and then reopen and re-select all the shortcuts you want to
see in the menu. See this page for
background information.
