Recently, reinstalling any qube templates from dom0 are failing, probably after one of the recent dom0 updates. If I type my usual command to reinstall any (in the example Fedora 40), what I get back after the usual first couple of lines is the following:
qvm-template: error: Same version of template ‘fedora-40’ not found.
I already have a workaround, as I can delete and reinstall the templates, but I still want to solve this problem. Does anyone have an idea, what could cause this?
