New install of Qubes
Did not choose DispVMs in initial configuration.
Restored appVMs from backup.
Loaded DispVMs using dom0$ sudo qubesctl state.sls qvm.default-dvm
debian-10-dvm template was created as expected
dom0$ qvm-run --dispvm=debian-10-dvm qubes.StartApp+xterm
disp5685: command failed with code: 127
I have a working, default debian-10-dvm and can reproduce your error. I guess the last command must be wrong.
Yes, I copied that command from instructions on this board. Intuitively
dom0$ qvm–run --dispvm=debian-10-dvm xterm
should work, and it does. Thanks.
unman
4
qubes.StartApp calls a desktop file - on Debian, the file is named
debian-xterm.
So you need to call qubes.StartApp+debian-xterm
qvm-run in other forms calls the program by name - xterm
