I want to use a sys-gui-gpu qube to get gpu away from dom0…
In my Laptop BIOS I can enable or disable NVIDIA Optimus, when disabled the intel GPU is turned off and only GPU is the NVIDIA Quadro, HDMI and Display is then attached to the NVIDIA GPU.
Would this be the preferred way (without Optimus, only NVIDIA GPU)?
Just tried this setting and noticed the prompt to enter disk password is now without eye candy and after entering I only get the three points (busy indicator) but no login window… I then can turn off the laptop with power button (it seems to shut down correctly)… Windows boots fine with this setting and only shows NVIDIA GPU in device manager…
This is not exactly the case, as I installed on another laptop only with igpu (intel) then cloned to a new ssd which now sits in the new laptop. Is there a way to switch to discrete mode without reinstalling?
Or maybe just setup the sys-gui-gpu just the way it is now? What would be better?
