Reboot Failing (Failed to read reboot parameter file)
my qubes dont reboot … when i try to reboot(menu → power → reboot) i receive the message:
Failed to read reboot parameter file: No such file or directory rebooting.
then stucks in a black screen and dont reboot…
I moved your post to the User Support category @smlt, because it seemed more adequate to me. Please feel free to move it back if you disagree :slightly_smiling_face:
Do you mean the Qubes system itself?
Which version of Qubes are you running?
Do you see any error messages before the “reboot parameter file”
message?
im running r4.0
And do you mean the Qubes system?
yes qubes 4.0
@unman the image reads
[   OK   ] Removed slice system-systemd\x2dcryptsetup.slice.
[   OK   ] Reached target Shutdown.
[23889.266187] watchdog0: watchdog did not stop!
[23890.653540] watchdog0: watchdog did not stop!
dracut Warning: Killing all remaining processes
Rebooting.
[23891.210229] reboot: Restarting system
yes but it freeze on this and dont reboot
@deeplow Thanks for that detail - it’s much appreciated.
That warning is (I think) spurious and fixed in current systemd - it’s a
consequence here of an older dom0.
It doesnt explain the failure to reboot: on that, I have no idea.
Im having the same issue
Recently I noticed those
messages too. But the system still successfully restarts.
