I’m trying to run Reaper inside an AppVM based off the Debian 11 template. I can confirm that pulseaudio is working fine, because I can watch videos and listen to music from within the AppVM.
Somehow Reaper doesn’t like the underlying sound setup, even though I explicitly configure it to use pulseaudio. When I open pavucontrol, all configs seem to be fine – I can’t see anything out of place.
I’m trying to avoid having to resort to a Windows VM for this, given that my usual workflow with Reaper on Linux has always been fine.
I’ve just installed Qubes 4.1.0-rc4 and i’m running Reaper in a AppVM(Fedora-34) with a Zoom UAC-8 USB3 audio interface via Jack/Qjackctl.
Unfortunately the app freezes if i choose Pulseaudio as Audio System on Reaper Preferences/Audio Device Settings.
I would recommend to use Reaper with Jack as a sound server installed in you Debian 11 template.
Hello! can you clarify how to get sound working on Reaper with jack? I’ve set up a jack server with cadence dummy driver but that doesn’t output to qubes audio even with pulseaudio-jack bridge. If I select alsa driver, then it fails to start hw:0 interface
logs:
Wed Jul 27 17:13:40 2022: Starting jack server...
Wed Jul 27 17:13:40 2022: JACK server starting in realtime mode with priority 10
Wed Jul 27 17:13:40 2022: self-connect-mode is "Don't restrict self connect requests"
Wed Jul 27 17:13:40 2022: ERROR: control open "hw:0" (No such file or directory)
Wed Jul 27 17:13:40 2022: creating alsa driver ... hw:0|hw:0|1024|2|48000|1|1|nomon|swmeter|-|32bit
Wed Jul 27 17:13:40 2022: ERROR: ALSA: Cannot open PCM device alsa_pcm for playback. Falling back to capture-only mode
Wed Jul 27 17:13:40 2022: ERROR: Cannot initialize driver
Wed Jul 27 17:13:40 2022: ERROR: JackServer::Open failed with -1
Wed Jul 27 17:13:40 2022: ERROR: Failed to open server
I’ve gotten it to work connecting an external interface, but many times I just need to edit existing audio, so using external interface not needed and would prefer to work with qubes audio directly.
