Realtek Wi Fi adapter not recognized
Recently I installed Qubes OS version 4.2. However, I have issues with my Wi Fi connectivity as my adapter is not being recognized. For my sys-net service I am using debian-12 with kernel 6.6.2-1.fc37.
root@sys-net:~# lspci | grep Network
00:06.0 Network controller: Realtek Semiconductor Co., Ltd. Device b852
In other topics I read that this adapter is associated with kernel module rtw89_8852be, which in my case is linked to my adapter, however, it still appears as UNCLAIMED.
        *-network:0 UNCLAIMED
             description: Network controller
             product: Realtek Semiconductor Co., Ltd.
             vendor: Realtek Semiconductor Co., Ltd.
             physical id: 6
             bus info: pci@0000:00:06.0
             version: 00
             width: 64 bits
             clock: 33MHz
             capabilities: pm msi pciexpress cap_list
             configuration: latency=0
             resources: ioport:c200(size=256) memory:f2000000-f20fffff
	Subsystem: Lenovo Device 4853
	Physical Slot: 6
	Flags: fast devsel, IRQ 40
	I/O ports at c200 [size=256]
	Memory at f2000000 (64-bit, non-prefetchable) [size=1M]
	Capabilities: [40] Power Management version 3
	Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
	Capabilities: [70] Express Endpoint, MSI 00
	Kernel modules: rtw89_8852be
I can see an error in the kernel logs when the rtw89_8852be module is being loaded.
root@sys-net:~# dmesg | grep rtw
[    2.317494] rtw89_8852be 0000:00:06.0: Direct firmware load for rtw89/rtw8852b_fw-1.bin failed with error -2
[    2.331979] rtw89_8852be 0000:00:06.0: loaded firmware rtw89/rtw8852b_fw.bin
[    2.335329] rtw89_8852be 0000:00:06.0: Firmware version 0.27.32.1 (ef7920a3), cmd version 0, type 1
[    2.335344] rtw89_8852be 0000:00:06.0: Firmware version 0.27.32.1 (ef7920a3), cmd version 0, type 3
[    2.335362] rtw89_8852be 0000:00:06.0: MAC has already powered on
[    2.356903] rtw89_8852be 0000:00:06.0: [ERR]pci config read 719
[    2.356918] rtw89_8852be 0000:00:06.0: [ERR] pcie autok fail -22
[    2.356927] rtw89_8852be 0000:00:06.0: failed to setup chip information
[    2.359618] rtw89_8852be: probe of 0000:00:06.0 failed with error -22
I would be really thankful to hear any ideas how we can fix this issue.
What’s your adapter VID:PID?
You can check it with:
lspci -vnn -s 00:06.0
Maybe you can try to use newer firmware in sys-net.
Maybe related:
root@sys-net:~# lspci -vnn -s 00:06.0
00:06.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. Device [10ec:b852]
	Subsystem: Lenovo Device [17aa:4853]
	Physical Slot: 6
Hi there.
I think to have the same issue on my:
HP ProBook 450 G10
WiFi kernel module is the same, so I think recent driver update of MSWin11 device has changed something and now the same update is needed on Xen/Fedora kernel side.
I’ve tried also latest kernel 6.19, without success.
Only ethernet working…
from sys-net I can see “missing” device (nmcli -p g), but wifi hardware is present in fedora43 logs.
Also rolling back to previous kernel version, doesn’t solve the issue.
I hope this can help.
Cheers.
M.
