Only problem is the ethernet
That's not a problem with "permissive=true" and "no-strict-rest=true".
I'm fighting with this laptop, but no luck using the Ethernet interface ![]()
Tried all mentioned qvm-pci options, but the result is always the same:
[ 15.149961] ------------[ cut here ]------------
[ 15.150028] NETDEV WATCHDOG: ens6 (e1000e): transmit queue 0 timed out
[ 15.150093] WARNING: CPU: 0 PID: 0 at /home/user/rpmbuild/BUILD/kernel-latest-5.8.16/linux-5.8.16/net/sched/sch_generic.c:443 dev_watchdog+0x259/0x260
[ 15.150166] Modules linked in: xt_nat nft_ct nf_tables nfnetlink rfkill xt_REDIRECT ip6table_filter ip6_tables ipt_REJECT nf_reject_ipv4 xt_conntrack iptable_filter xt_MASQUERADE iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 joydev intel_rapl_msr drm_vram_helper drm_ttm_helper intel_rapl_common ttm crct10dif_pclmul crc32_pclmul crc32c_intel drm_kms_helper ghash_clmulni_intel rapl cec snd_pcm snd_timer ehci_pci snd e1000e soundcore pcspkr drm ehci_hcd serio_raw ata_generic i2c_piix4 pata_acpi floppy xenfs xen_netback u2mfn(O) xen_privcmd xen_gntdev xen_gntalloc xen_blkback xen_evtchn ip_tables overlay xen_blkfront
[ 15.150409] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G O 5.8.16-1.qubes.x86_64 #1
[ 15.150466] Hardware name: Xen HVM domU, BIOS 4.8.5-25.fc25 10/20/2020
[ 15.150516] RIP: 0010:dev_watchdog+0x259/0x260
[ 15.150560] Code: 48 85 c0 75 e4 eb 9b 4c 89 ef c6 05 f4 b2 de 00 01 e8 1b bf fa ff 89 d9 48 89 c2 4c 89 ee 48 c7 c7 50 24 46 82 e8 47 e1 6a ff <0f> 0b e9 7a ff ff ff 0f 1f 44 00 00 41 57 41 56 49 89 d6 41 55 41
[ 15.150652] RSP: 0018:ffffb49640003e78 EFLAGS: 00010286
[ 15.150695] RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000000
[ 15.150747] RDX: 0000000000000001 RSI: 00000000000000f6 RDI: 0000000000000300
[ 15.150799] RBP: ffff9ccc100d03dc R08: ffffb49640005000 R09: 00000000000001ee
[ 15.150851] R10: ffffb49640003f08 R11: ffff9ccc15c6af80 R12: ffff9ccc132f3280
[ 15.150903] R13: ffff9ccc100d0000 R14: ffff9ccc100d0480 R15: 0000000000000001
[ 15.150957] FS: 0000000000000000(0000) GS:ffff9ccc17000000(0000) knlGS:0000000000000000
[ 15.151012] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 15.151061] CR2: 00007b0a14090064 CR3: 0000000007e04001 CR4: 00000000001606f0
[ 15.151117] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 15.151170] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
[ 15.151222] Call Trace:
[ 15.151258] <IRQ>
[ 15.151296] ? pfifo_fast_reset+0x110/0x110
[ 15.151338] call_timer_fn+0x2d/0x130
[ 15.151498] run_timer_softirq+0x37b/0x930
[ 15.151542] __do_softirq+0x11a/0x2d9
[ 15.151583] asm_call_irq_on_stack+0x12/0x20
[ 15.151626] </IRQ>
[ 15.151662] do_softirq_own_stack+0x37/0x40
[ 15.151702] irq_exit_rcu+0xd1/0xe0
[ 15.151742] sysvec_xen_hvm_callback+0x34/0x80
[ 15.151787] asm_sysvec_xen_hvm_callback+0x12/0x20
[ 15.151831] RIP: 0010:native_safe_halt+0xe/0x10
[ 15.151875] Code: ff eb bc cc cc cc cc cc cc cc cc cc e9 07 00 00 00 0f 00 2d 96 25 46 00 f4 c3 66 90 e9 07 00 00 00 0f 00 2d 86 25 46 00 fb f4 <c3> cc 0f 1f 44 00 00 41 55 41 54 55 53 e8 30 0e 5c ff 65 8b 2d e9
[ 15.151966] RSP: 0018:ffffffff82603dc0 EFLAGS: 00000246
[ 15.152009] RAX: 0000000000004000 RBX: ffff9ccc154de800 RCX: 0000000000000034
[ 15.152061] RDX: 4ec4ec4ec4ec4ec5 RSI: ffffffff8277c660 RDI: ffff9ccc154de864
[ 15.152114] RBP: ffff9ccc154de864 R08: 000000002d3d6f42 R09: 0000000000000000
[ 15.152166] R10: 0000000000000018 R11: 00000000ffffffff R12: 0000000000000001
[ 15.152219] R13: 0000000000000001 R14: 0000000000000001 R15: ffffffff82614840
[ 15.152273] acpi_safe_halt+0x1c/0x30
[ 15.152313] acpi_idle_enter+0xe6/0x280
[ 15.152353] cpuidle_enter_state+0x81/0x430
[ 15.152393] cpuidle_enter+0x29/0x40
[ 15.152433] do_idle+0x231/0x2f0
[ 15.152473] cpu_startup_entry+0x19/0x20
[ 15.152516] start_kernel+0xa64/0xaa8
[ 15.152558] secondary_startup_64+0xb6/0xc0
[ 15.152598] ---[ end trace 0e449a39d5e1e47c ]---
I also having these errors:
[ 15.154783] e1000e 0000:00:06.0 ens6: Reset adapter unexpectedly
[ 18.906826] e1000e 0000:00:06.0 ens6: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: Rx/Tx
[ 21.104136] e1000e 0000:00:06.0 ens6: Detected Hardware Unit Hang:
[ 21.104136] TDH <0>
[ 21.104136] TDT <1>
[ 21.104136] next_to_use <1>
[ 21.104136] next_to_clean <0>
[ 21.104136] buffer_info[next_to_clean]:
[ 21.104136] time_stamp <fffbb4b0>
[ 21.104136] next_to_watch <0>
[ 21.104136] jiffies <fffbbd42>
[ 21.104136] next_to_watch.status <0>
[ 21.104136] MAC Status <80083>
[ 21.104136] PHY Status <796d>
[ 21.104136] PHY 1000BASE-T Status <3800>
[ 21.104136] PHY Extended Status <3000>
[ 21.104136] PCI Status <10>
tried with kernel latest, and kernel 4.19
Can you give me some details how are you menaged to use it?
Given the fact that
- the external monitor not working,
- the CPU is mostly around 90C, then the fan is always sounds like jet.
a I'm tending to throw away this crap pretty soon. :((
