This works on the 4.2.1 release, this person made updates to switch from iptables to nftables.
https://github.com/1cho1ce/Qubes-vpn-support/tree/replace-iptables-with-nftables
Chris
Chris
That seems promising.
Does it mean that the whole procedure is still the same just instead of unzipping the 1.4.4 one downloads the replace-iptables-with-nftables and it should work as the original 1.4.4 on Qubes 4.1.
Will it work as a VPN over Tor including the Tor browser?
Chris Bensch:
So with the script replace-iptables-with-nftables I get LINK UP. Works nicely.
The only issue is that if I set the NetVM to the mullvad-vpn proxy for the anon-whonix AppVM, in Tor Browser or in terminal, I don't get a connection.
But if I set a NetVM mullvad-vpn proxy for normal debian AppVM Firefox, it works like a breeze.
It seems that it could be an issue with the Whonix. Are there any limitations in the Whonix design that prevent the beast from connecting to the VPN over Tor? I remember that the 1.4.4 in the Qubes 4.1 it was working.
Any workarounds?
'taran1s' via qubes-users:
