I haven’t been able to get qvm-run export proxy to work in scripts that run from dom0, downloading files in a qube. Any ideas why?
Ref: This script works running in qube:
#!/bin/bash
# Installs the latest .deb version of Electron Mail.
# For export proxy to work it must run with root priviliges in some qube configs.
owner='vladimiry'
repo='ElectronMail'
download_name='electron-mail.deb'
notify(){
echo "$1"; notify-send "$1"
export 'https_proxy=127.0.0.1:8082'
latest_release=$(curl -s "https://api.github.com/repos/$owner/$repo/releases/latest")
download_url=$(echo "$latest_release" | grep -o '"browser_download_url": ".*\.deb"' | cut -d '"' -f 4)
echo "deb_download_url: $download_url"
# Step 1: Set the downloads directory
downloads_dir="/tmp"
# Step 2: Delete the file if it already exists in the downloads directory
file_path="$downloads_dir/$download_name"
if [ -f "$file_path" ]; then
sudo rm "$file_path"
fi
# Step 3: Download the *.deb file to the downloads directory
curl -L "$download_url" -o "$file_path"
# Step 4: Calculate the SHA256 hash of the downloaded file
file_hash=$(sha256sum "$file_path" | awk '{print $1}')
echo "File hash: $file_hash"
# Step 5: Check if the hash exists in the release page
hash_check=$(curl -s "https://github.com/$owner/$repo/releases" | grep -q "$file_hash" && echo "Hash found" || echo "Hash not found")
# Step 6: Install the *.deb file if the hash check passed and remove the file
if [ "$hash_check" = "Hash found" ]; then
sudo dpkg -i "$file_path"
rm "$file_path"
else
notify "Hash check failed. Installation aborted."
rm "$file_path"
fi
The dom0 version won’t work. The proxy seems to be the problem:
#!/bin/bash
# Downloads, verifies, and installs the latest .deb version of Electron Mail.
# Runs from dom0
# $1=install qube name.
# NOT WORKING
# Uset the version that runs in qube.
# Check if target_qube parameter is provided
if [ -z "$1" ]; then
echo "Please provide qube as a parameter."
exit 1
fi
target_qube="$1"
owner='vladimiry'
repo='ElectronMail'
hash_check=''
notify(){
echo "$1"
notify-send "$1"
# Download and verify in qube.
qvm-run --pass-io -u root "$target_qube" "
sudo apt update && apt upgrade -y && apt autoremove -y &&
sudo apt install -y qubes-core-agent-networking curl &&
export 'https_proxy=127.0.0.1:8082' &&
latest_release=$(curl -s \"https://api.github.com/repos/$owner/$repo/releases/latest\") &&
wait && # prevent reace condition
echo \"Latest release: $latest_release\" &&
download_url=$(echo \"$latest_release\" | grep -o '"browser_download_url": ".*\.deb"' | cut -d '"' -f 4) &&
echo \"Download url: $download_url\" &&
downloads_dir='/tmp' &&
file_path=\"$downloads_dir/$download_name\" &&
curl -L \"$download_url\" -o \"$file_path\" &&
file_hash=$(sha256sum \"$file_path\" | awk '{print $1}')&&
hash_check=$(curl -s \"https://github.com/$owner/$repo/releases\" | grep -q \"$file_hash\" && echo \"Hash found\" || echo \"Hash not found\")
# Guard: Hash failed.
if [ "$hash_check" = "Hash not found" ]; then
qvm-run --pass-io -u root "$target_qube" "rm \"$file_path\""
exit 1
fi
# Install
sudo dpkg -i \"$file_path\" &&
rm \"$file_path\"
