Journalctl -p 3 -x -x -3 > journal.log
-- Logs begin at Mon 2022-08-15 06:26:46 EDT, end at Thu 2022-08-25 10:14:32 EDT. --
Aug 24 07:08:31 dom0 systemd-vconsole-setup[226]: /usr/bin/setfont failed with exit status 71.
Aug 24 07:08:34 dom0 systemd-vconsole-setup[419]: /usr/bin/setfont failed with exit status 71.
Aug 24 07:09:18 dom0 xenstored[1984]: Checking store ...
Aug 24 07:09:18 dom0 xenstored[1984]: Checking store complete.
Aug 24 07:09:51 dom0 libvirtd[1987]: internal error: Unable to reset PCI device 0000:00:14.0: no FLR, PM reset or bus reset available
Aug 24 07:10:38 dom0 pulseaudio[7770]: ALSA woke us up to write new data to the device, but there was actually nothing to write.
Aug 24 07:10:38 dom0 pulseaudio[7770]: Most likely this is a bug in the ALSA driver 'snd_hda_intel'. Please report this issue to the ALSA developers.
Aug 24 07:10:38 dom0 pulseaudio[7770]: We were woken up with POLLOUT set -- however a subsequent snd_pcm_avail() returned 0 or another value < min_avail.
Aug 24 07:13:42 dom0 qmemman.systemstate[1973]: Xen free = 79289612 too small for satisfy assignments! assigned_but_unused=66918093, domdict={'0': {'memory_current': 4172599296, 'memory_actual': 4189377589, 'memory_maximum': 4294967296, 'mem_used': 1054068736, 'id': '0', 'last_target': 4189377589, 'no_progress': False, 'slow_memset_react': False}, '1': {'memory_current': 297840640, 'memory_actual': 297840640, 'memory_maximum': 314572800, 'mem_used': None, 'id': '1', 'last_target': 297795584, 'no_progress': False, 'slow_memset_react': False}, '2': {'memory_current': 150994944, 'memory_actual': 150994944, 'memory_maximum': 150994944, 'mem_used': None, 'id': '2', 'last_target': 150994944, 'no_progress': False, 'slow_memset_react': False}, '3': {'memory_current': 402698240, 'memory_actual': 402698240, 'memory_maximum': 419430400, 'mem_used': None, 'id': '3', 'last_target': 402653184, 'no_progress': False, 'slow_memset_react': False}, '4': {'memory_current': 150994944, 'memory_actual': 150994944, 'memory_maximum': 150994944, 'mem_used': None, 'id': '4', 'last_target': 150994944, 'no_progress': False, 'slow_memset_react': False}, '5': {'memory_current': 3553685504, 'memory_actual': 3570399440, 'memory_maximum': 4194304000, 'mem_used': 470765568, 'id': '5', 'last_target': 3570399440, 'no_progress': False, 'slow_memset_react': False}, '6': {'memory_current': 3835637760, 'memory_actual': 3852351213, 'memory_maximum': 4194304000, 'mem_used': 520822784, 'id': '6', 'last_target': 3852351213, 'no_progress': False, 'slow_memset_react': False}, '7': {'memory_current': 3613577216, 'memory_actual': 3630289627, 'memory_maximum': 4194304000, 'mem_used': 481361920, 'id': '7', 'last_target': 3630289627, 'no_progress': False, 'slow_memset_react': False}, '8': {'memory_current': 419500032, 'memory_actual': 419500032, 'memory_maximum': 4194304000, 'mem_used': None, 'id': '8', 'last_target': 419430400, 'no_progress': False, 'slow_memset_react': False}}
Aug 24 07:13:42 dom0 qmemman.systemstate[1973]: Xen free = 136989884 too small for satisfy assignments! assigned_but_unused=161669911, domdict={'0': {'memory_current': 4172599296, 'memory_actual': 4294967296, 'memory_maximum': 4294967296, 'mem_used': 1033220096, 'id': '0', 'last_target': 4294967296, 'no_progress': False, 'slow_memset_react': False}, '1': {'memory_current': 297840640, 'memory_actual': 297840640, 'memory_maximum': 314572800, 'mem_used': None, 'id': '1', 'last_target': 297795584, 'no_progress': False, 'slow_memset_react': False}, '2': {'memory_current': 150994944, 'memory_actual': 150994944, 'memory_maximum': 150994944, 'mem_used': None, 'id': '2', 'last_target': 150994944, 'no_progress': False, 'slow_memset_react': False}, '3': {'memory_current': 402698240, 'memory_actual': 402698240, 'memory_maximum': 419430400, 'mem_used': None, 'id': '3', 'last_target': 402653184, 'no_progress': False, 'slow_memset_react': False}, '4': {'memory_current': 150994944, 'memory_actual': 150994944, 'memory_maximum': 150994944, 'mem_used': None, 'id': '4', 'last_target': 150994944, 'no_progress': False, 'slow_memset_react': False}, '5': {'memory_current': 3503243264, 'memory_actual': 3519957814, 'memory_maximum': 4194304000, 'mem_used': 470765568, 'id': '5', 'last_target': 3519957814, 'no_progress': False, 'slow_memset_react': False}, '6': {'memory_current': 3775119360, 'memory_actual': 3791831545, 'memory_maximum': 4194304000, 'mem_used': 520822784, 'id': '6', 'last_target': 3791831545, 'no_progress': False, 'slow_memset_react': False}, '7': {'memory_current': 3571634176, 'memory_actual': 3577509352, 'memory_maximum': 4194304000, 'mem_used': 481361920, 'id': '7', 'last_target': 3577509352, 'no_progress': False, 'slow_memset_react': False}, '8': {'memory_current': 419500032, 'memory_actual': 419500032, 'memory_maximum': 4194304000, 'mem_used': None, 'id': '8', 'last_target': 419430400, 'no_progress': False, 'slow_memset_react': False}}
Aug 24 07:22:09 dom0 systemd-coredump[10222]: Process 7712 (xss-lock) of user 1000 dumped core.
Stack trace of thread 7712:
#0 0x0000743c2a542fc2 g_logv (libglib-2.0.so.0 + 0x59fc2)
#1 0x0000743c2a543233 g_log (libglib-2.0.so.0 + 0x5a233)
#2 0x000055c758cc3be5 screensaver_event_cb (xss-lock + 0x4be5)
#3 0x000055c758cc3cdf xcb_event_dispatch (xss-lock + 0x4cdf)
#4 0x0000743c2a53b78f g_main_context_dispatch (libglib-2.0.so.0 + 0x5278f)
#5 0x0000743c2a53bb18 g_main_context_iterate.constprop.0 (libglib-2.0.so.0 + 0x52b18)
#6 0x0000743c2a53be33 g_main_loop_run (libglib-2.0.so.0 + 0x52e33)
#7 0x000055c758cc2ecd main (xss-lock + 0x3ecd)
#8 0x0000743c2a309082 __libc_start_main (libc.so.6 + 0x27082)
#9 0x000055c758cc302e _start (xss-lock + 0x402e)
Stack trace of thread 7724:
#0 0x0000743c2a3d886f __poll (libc.so.6 + 0xf686f)
#1 0x0000743c2a53baae g_main_context_iterate.constprop.0 (libglib-2.0.so.0 + 0x52aae)
#2 0x0000743c2a53be33 g_main_loop_run (libglib-2.0.so.0 + 0x52e33)
#3 0x0000743c2a78f6aa gdbus_shared_thread_func (libgio-2.0.so.0 + 0x1226aa)
#4 0x0000743c2a5657f2 g_thread_proxy (libglib-2.0.so.0 + 0x7c7f2)
#5 0x0000743c2a200432 start_thread (libpthread.so.0 + 0x9432)
#6 0x0000743c2a3e36d3 __clone (libc.so.6 + 0x1016d3)
Stack trace of thread 7716:
#2 0x0000743c2a53bbe3 g_main_context_iteration (libglib-2.0.so.0 + 0x52be3)
#3 0x0000743c2a53bc31 glib_worker_main (libglib-2.0.so.0 + 0x52c31)
-- Subject: Process 7712 (xss-lock) dumped core
-- Defined-By: systemd
-- Support: https://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Documentation: man:core(5)
-- Process 7712 (xss-lock) crashed and dumped core.
-- This usually indicates a programming error in the crashing program and
-- should be reported to its vendor as a bug.
Aug 24 07:22:14 dom0 qrexec-policy-e[10242]: error calling qrexec-policy-agent in dom0
File "/usr/lib/python3.8/site-packages/qrexec/tools/qrexec_policy_exec.py", line 133, in execute
await super().execute(caller_ident)
File "/usr/lib/python3.8/site-packages/qrexec/policy/parser.py", line 556, in execute
raise ExecutionFailed('qrexec-client failed: {}'.format(command))
qrexec.exc.ExecutionFailed: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,sys-net,3', '-E', 'QUBESRPC qubes.WindowIconUpdater+ sys-net keyword adminvm']
During handling of the above exception, another exception occurred:
File "/usr/lib/python3.8/site-packages/qrexec/tools/qrexec_policy_exec.py", line 151, in notify
await call_socket_service(guivm, service, source_domain, params)
File "/usr/lib/python3.8/site-packages/qrexec/server.py", line 105, in call_socket_service_local
reader, writer = await asyncio.open_unix_connection(path)
File "/usr/lib64/python3.8/asyncio/streams.py", line 111, in open_unix_connection
transport, _ = await loop.create_unix_connection(
File "/usr/lib64/python3.8/asyncio/unix_events.py", line 244, in create_unix_connection
await self.sock_connect(sock, path)
File "/usr/lib64/python3.8/asyncio/selector_events.py", line 496, in sock_connect
return await fut
File "/usr/lib64/python3.8/asyncio/selector_events.py", line 501, in _sock_connect
sock.connect(address)
ConnectionRefusedError: [Errno 111] Connection refused
Aug 24 07:22:14 dom0 qrexec[10242]: qubes.WindowIconUpdater: sys-net -> dom0: error while executing: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,sys-net,3', '-E', 'QUBESRPC qubes.WindowIconUpdater+ sys-net keyword adminvm']
Aug 24 07:22:15 dom0 qrexec-policy-e[10224]: error calling qrexec-policy-agent in dom0
qrexec.exc.ExecutionFailed: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,sys-whonix,6', '-E', 'QUBESRPC qubes.WindowIconUpdater+ sys-whonix keyword adminvm']
return await fut
Aug 24 07:22:15 dom0 qrexec[10224]: qubes.WindowIconUpdater: sys-whonix -> dom0: error while executing: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,sys-whonix,6', '-E', 'QUBESRPC qubes.WindowIconUpdater+ sys-whonix keyword adminvm']
Aug 24 07:22:15 dom0 qrexec-policy-e[10226]: error calling qrexec-policy-agent in dom0
qrexec.exc.ExecutionFailed: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,***REDACTED***,8', '-E', 'QUBESRPC qubes.WindowIconUpdater+ ***REDACTED*** keyword adminvm']
return await fut
Aug 24 07:22:15 dom0 qrexec[10226]: qubes.WindowIconUpdater: ***REDACTED*** -> dom0: error while executing: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,***REDACTED***,8', '-E', 'QUBESRPC qubes.WindowIconUpdater+ ***REDACTED*** keyword adminvm']
Aug 24 07:22:15 dom0 qrexec-policy-e[10231]: error calling qrexec-policy-agent in dom0
qrexec.exc.ExecutionFailed: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,sys-firewall,5', '-E', 'QUBESRPC qubes.WindowIconUpdater+ sys-firewall keyword adminvm']
return await fut
Aug 24 07:22:15 dom0 qrexec[10231]: qubes.WindowIconUpdater: sys-firewall -> dom0: error while executing: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,sys-firewall,5', '-E', 'QUBESRPC qubes.WindowIconUpdater+ sys-firewall keyword adminvm']
Aug 24 07:22:15 dom0 qrexec-policy-e[10225]: error calling qrexec-policy-agent in dom0
qrexec.exc.ExecutionFailed: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,***REDACTED2***,7', '-E', 'QUBESRPC qubes.WindowIconUpdater+ ***REDACTED2*** keyword adminvm']
return await fut
Aug 24 07:22:15 dom0 qrexec[10225]: qubes.WindowIconUpdater: ***REDACTED2*** -> dom0: error while executing: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,***REDACTED2***,7', '-E', 'QUBESRPC qubes.WindowIconUpdater+ ***REDACTED2*** keyword adminvm']
Aug 24 07:22:15 dom0 qrexec-policy-e[10264]: error calling qrexec-policy-agent in dom0
qrexec.exc.ExecutionFailed: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,sys-usb,1', '-E', 'QUBESRPC qubes.WindowIconUpdater+ sys-usb keyword adminvm']
return await fut
Aug 24 07:22:15 dom0 qrexec[10264]: qubes.WindowIconUpdater: sys-usb -> dom0: error while executing: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,sys-usb,1', '-E', 'QUBESRPC qubes.WindowIconUpdater+ sys-usb keyword adminvm']
Aug 24 07:22:34 dom0 libvirtd[1987]: internal error: Unable to reset PCI device 0000:00:14.0: no FLR, PM reset or bus reset available
Aug 24 07:22:54 dom0 systemd-cryptsetup[12754]: Device luks-b62932d3-916a-4028-85eb-7ceb039d0c7b is still in use.
Aug 24 07:22:54 dom0 systemd-cryptsetup[12754]: Failed to deactivate: Device or resource busy
Aug 24 07:22:54 dom0 systemd[1]: Failed unmounting mount xenstore file system.
-- Subject: A stop job for unit var-lib-xenstored.mount has finished
-- A stop job for unit var-lib-xenstored.mount has finished.
-- The job identifier is 3733 and the job result is failed.
