Thank you!
- Increasing the qrexec_timeout has not worked
- I figured out the vchan client was disconnected according to the logs.
- I have not changed the template, it was using fedora-41-xfce as before the upgrade in
default-dvm
- I think the only thing that changed was the VM kernel version that was changed in the dist upgrade.
- Tried updating to the latest kernel and using it for the sys-usb VM (6.15.10-1.fc41), no effect. Tried the kernel that was being used before (6.12.47-1.fc37), the behaviour is the same.
- When I remove the passthrough of the PCI-USB device, the
sys-usb VM runs normally without the vchan and qrexec timeouts (got the idea from a similar error as in this thread for sys-firewall)
- The system is a Thinkpad X270, if this may affect the behaviour
- After booting,
journalctl -x | grep sys-usb does not generate any lines… it seems the VM is not being started.
/var/log/xen/console/guest-sys-usb.log has only one entry, which is Logfile Opened.
/var/log/xen/console/guest-sys-usb-dm.log has more info, these are the last lines:
[2025-09-28 09:58:45] Logfile Opened
[2025-09-29 22:19:39] ==== Press enter for shell ====
[2025-09-29 22:19:39] + read
[2025-09-29 22:19:39] + vchan-socket-proxy '--mode=server' '--reconnect-marker=1' --verbose 0 device-model/23/qmp-vchan /tmp/qemu.qmp
[2025-09-29 22:19:39] qubes_gui/init: 574
[2025-09-29 22:19:39] qubes_gui/init: 583
[2025-09-29 22:19:39] qubes_gui/init: 586
[2025-09-29 22:19:39] qubes_gui/init[613]: version sent, waiting for xorg conf
[2025-09-29 22:19:39] from-unix: {"QMP": {"version": {"qemu": {"micro": 2, "minor": 0, "major": 9}, "package": ""}, "capabilities": ["oob"]}}
[2025-09-29 22:19:39] wrote 110 bytes to vchan
[2025-09-29 22:19:39] from-vchan:
[2025-09-29 22:19:39] {"return": {}}
[2025-09-29 22:19:39] from-vchan: {"execute":"qmp_capabilities","id":2020372737}
[2025-09-29 22:19:39] from-unix: {"return": {}, "id": 2020372737}
[2025-09-29 22:19:39] wrote 34 bytes to vchan
[2025-09-29 22:19:39] from-vchan: {"execute":"device_add","id":2020372736,"arguments":{"driver":"xen-pci-passthrough","id":"pci-pt-00_14.0","hostaddr":"0000:00:14.0"}}
[2025-09-29 22:19:39] [00:06.0] xen_pt_realize: Assigning real physical device 00:14.0 to devfn 0x30
[2025-09-29 22:19:39] [00:06.0] xen_pt_register_regions: IO region 0 registered (size=0x00010000 base_addr=0xe1220000 type: 0x4)
[2025-09-29 22:19:39] [00:06.0] xen_pt_config_reg_init: Offset 0x0006 mismatch! Emulated=0x0010, host=0x0290, syncing to 0x0290.
[2025-09-29 22:19:39] [00:06.0] xen_pt_config_reg_init: Offset 0x0010 mismatch! Emulated=0x0000, host=0xe1220004, syncing to 0xe1220004.
[2025-09-29 22:19:39] [00:06.0] xen_pt_config_reg_init: Offset 0x0072 mismatch! Emulated=0x0000, host=0x01c2, syncing to 0x0002.
[2025-09-29 22:19:39] [00:06.0] xen_pt_pm_ctrl_reg_init_off: PCI power management control passthrough is off
[2025-09-29 22:19:39] [00:06.0] xen_pt_config_reg_init: Offset 0x0082 mismatch! Emulated=0x0000, host=0x0086, syncing to 0x0080.
[2025-09-29 22:19:39] [00:06.0] xen_pt_pci_intx: intx=1
[2025-09-29 22:19:39] [00:06.0] xen_pt_realize: Real physical device 00:14.0 registered successfully
[2025-09-29 22:19:39] from-unix: {"return": {}, "id": 2020372736}
[2025-09-29 22:19:39] from-vchan: {"execute":"query-pci","id":2020372738}
[2025-09-29 22:19:39] from-unix: {"return": [{"bus": 0, "devices": [{"irq_pin": 0, "bus": 0, "qdev_id": "", "slot": 0, "class_info": {"class": 1536, "desc": "Host bridge"}, "id": {"device": 4663, "subsystem-vendor": 6900, "vendor": 32902, "subsystem": 4352}, "function": 0, "regions": []}, {"irq_pin": 0, "bus": 0, "qdev_id": "", "slot": 1, "class_info": {"class": 1537, "desc": "ISA bridge"}, "id": {"device": 28672, "subsystem-vendor": 6900, "vendor": 32902, "subsystem": 4352}, "function": 0, "regions": []}, {"irq_pin": 0, "bus": 0, "qdev_id": "", "slot": 1, "class_info": {"class": 257, "desc": "IDE controller"}, "id": {"device": 28688, "subsystem-vendor": 6900, "vendor": 32902, "subsystem": 4352}, "function": 1, "regions": [{"bar": 4, "size": 16, "address": -1, "type": "io"}]}, {"irq_pin": 1, "bus": 0, "qdev_id": "", "irq": 0, "slot": 1, "class_info": {"class": 1664, "desc": "Bridge"}, "id": {"device": 28947, "subsystem-vendor": 6900, "vendor": 32902, "subsystem": 4352}, "function": 3, "regions": []}, {"irq_pin": 1, "bus": 0, "qdev_id": "", "irq": 0, "slot": 2, "class_info": {"class": 65408}, "id": {"device": 1, "subsystem-vendor": 22611, "vendor": 22611, "subsystem": 1}, "function": 0, "regions": [{"bar": 0, "size": 256, "address": -1, "type": "io"}, {"prefetch": true, "mem_type_64": false, "bar": 1, "size": 16777216, "address": -1, "type": "memory"}]}, {"irq_pin": 1, "bus": 0, "qdev_id": "", "irq": 0, "slot": 3, "class_info": {"class": 256, "desc": "SCSI controller"}, "id": {"device": 18, "subsystem-vendor": 0, "vendor": 4096, "subsystem": 4096}, "function": 0, "regions": [{"bar": 0, "size": 256, "address": -1, "type": "io"}, {"prefetch": false, "mem_type_64": false, "bar": 1, "size": 1024, "address": -1, "type": "memory"}, {"prefetch": false, "mem_type_64": false, "bar": 2, "size": 8192, "address": -1, "type": "memory"}]}, {"irq_pin": 0, "bus": 0, "qdev_id": "", "slot": 4, "class_info": {"class": 768, "desc": "VGA controller"}, "id": {"device": 4369, "subsystem-vendor": 6900, "vendor": 4660, "subsystem": 4352}, "function": 0, "regions": [{"prefetch": true, "mem_type_64": false, "bar": 0, "size": 16777216, "address": -1, "type": "memory"}, {"prefetch": false, "mem_type_64": false, "bar": 2, "size": 4096, "address": -1, "type": "memory"}, {"prefetch": false, "mem_type_64": false, "bar": 6, "size": 65536, "address": -1, "type": "memory"}]}, {"irq_pin": 4, "bus": 0, "qdev_id": "ehci", "irq": 0, "slot": 5, "class_info": {"class": 3075, "desc": "USB controller"}, "id": {"device": 9421, "subsystem-vendor": 6900, "vendor": 32902, "subsystem": 4352}, "function": 0, "regions": [{"prefetch": false, "mem_type_64": false, "bar": 0, "size": 4096, "address": -1, "type": "memory"}]}, {"irq_pin": 1, "bus": 0, "qdev_id": "pci-pt-00_14.0", "irq": 0, "slot": 6, "class_info": {"class": 0}, "id": {"device": 40239, "subsystem-vendor": 0, "vendor": 32902, "subsystem": 0}, "function": 0, "regions": [{"prefetch": false, "mem_type_64": true, "bar": 0, "size": 65536, "address": -1, "type": "memory"}]}]}], "id": 2020372738}
[2025-09-29 22:19:39] wrote 2048 bytes to vchan
[2025-09-29 22:19:39] wrote 973 bytes to vchan
[2025-09-29 22:19:39] vchan client disconnected
Now I’m getting a new error after I removed PCI-USB from passthrough and added it again in the devices list, but it seems to be unrelated to the errors above, so it’s maybe subject for a new thread or even a bug report. Now, when trying to start sys-usb manually from Qubes Manager, I get a pop-up with a message like “no response from qubesd”. Journalctl reveals that the Qubes API expects ASCII encoding while some parameter in the sys-usb start command payload seems to be UTF-8 now. When I installed Qubes 4.2, I selected pt-BR as the locale. I couldn’t revert this and this is where I am now.
sudo journalctl -x -e
set 29 22:39:32 dom0 qubesd[2690]: INFO: vm.sys-usb: Starting qube sys-usb
set 29 22:39:33 dom0 lvm[1247]: No longer monitoring thin pool qubes_dom0-vm--pool-tpool.
set 29 22:39:33 dom0 lvm[1247]: Monitoring thin pool qubes_dom0-vm--pool-tpool.
set 29 22:39:34 dom0 virtxend[3092]: erro interno: Falha ao redefinir o dispositivo de PCI 0000:00:14.0: não há nenhuma redefinição de FLR, PM ou redefinição de bus disponível
set 29 22:39:34 dom0 virtxend[3092]: Falha ao redefinir o dispositivo de PCI: erro interno: Falha ao redefinir o dispositivo de PCI 0000:00:14.0: não há nenhuma redefinição de FLR, PM ou redefinição de bus disponível
set 29 22:39:34 dom0 qubesd[2690]: ERROR: vm.sys-usb: Start failed: erro interno: Falha ao redefinir o dispositivo de PCI 0000:00:14.0: não há nenhuma redefinição de FLR, PM ou redefinição de bus disponível
set 29 22:39:34 dom0 qubesd[2690]: ERROR: unhandled exception while calling src=b'dom0' meth=b'admin.vm.Start' dest=b'sys-usb' arg=b'' len(untrusted_payload)=0
set 29 22:39:34 dom0 qubesd[2690]: Traceback (most recent call last):
set 29 22:39:34 dom0 qubesd[2690]: File "/usr/lib/python3.13/site-packages/qubes/vm/qubesvm.py", line 1468, in start
set 29 22:39:34 dom0 qubesd[2690]: self.libvirt_domain.createWithFlags(
set 29 22:39:34 dom0 qubesd[2690]: ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^
set 29 22:39:34 dom0 qubesd[2690]: libvirt.VIR_DOMAIN_START_PAUSED
set 29 22:39:34 dom0 qubesd[2690]: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
set 29 22:39:34 dom0 qubesd[2690]: )
set 29 22:39:34 dom0 qubesd[2690]: File "/usr/lib/python3.13/site-packages/qubes/app.py", line 107, in wrapper
set 29 22:39:34 dom0 qubesd[2690]: return getattr(self._vm, attrname)(*args, **kwargs)
set 29 22:39:34 dom0 qubesd[2690]: ~~~~~~~~~~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^
set 29 22:39:34 dom0 qubesd[2690]: File "/usr/lib64/python3.13/site-packages/libvirt.py", line 1415, in createWithFlags
set 29 22:39:34 dom0 qubesd[2690]: raise libvirtError('virDomainCreateWithFlags() failed')
set 29 22:39:34 dom0 qubesd[2690]: libvirt.libvirtError: erro interno: Falha ao redefinir o dispositivo de PCI 0000:00:14.0: não há nenhuma redefinição de FLR, PM ou redefinição de bus disponível
set 29 22:39:34 dom0 qubesd[2690]: During handling of the above exception, another exception occurred:
set 29 22:39:34 dom0 qubesd[2690]: File "/usr/lib/python3.13/site-packages/qubes/api/__init__.py", line 339, in respond
set 29 22:39:34 dom0 qubesd[2690]: response = await self.mgmt.execute(
set 29 22:39:34 dom0 qubesd[2690]: untrusted_payload=untrusted_payload
set 29 22:39:34 dom0 qubesd[2690]: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
set 29 22:39:34 dom0 qubesd[2690]: File "/usr/lib/python3.13/site-packages/qubes/api/admin.py", line 958, in vm_start
set 29 22:39:34 dom0 qubesd[2690]: await self.dest.start()
set 29 22:39:34 dom0 qubesd[2690]: File "/usr/lib/python3.13/site-packages/qubes/vm/dispvm.py", line 661, in start
set 29 22:39:34 dom0 qubesd[2690]: await super().start(**kwargs)
set 29 22:39:34 dom0 qubesd[2690]: File "/usr/lib/python3.13/site-packages/qubes/vm/qubesvm.py", line 1494, in start
set 29 22:39:34 dom0 qubesd[2690]: await self.fire_event_async(
set 29 22:39:34 dom0 qubesd[2690]: "domain-start-failed", reason=str(exc)
set 29 22:39:34 dom0 qubesd[2690]: File "/usr/lib/python3.13/site-packages/qubes/events.py", line 234, in fire_event_async
set 29 22:39:34 dom0 qubesd[2690]: sync_effects, async_effects = self._fire_event(
set 29 22:39:34 dom0 qubesd[2690]: ~~~~~~~~~~~~~~~~^
set 29 22:39:34 dom0 qubesd[2690]: event, kwargs, pre_event=pre_event
set 29 22:39:34 dom0 qubesd[2690]: File "/usr/lib/python3.13/site-packages/qubes/events.py", line 169, in _fire_event
set 29 22:39:34 dom0 qubesd[2690]: effect = func(self, event, **kwargs)
set 29 22:39:34 dom0 qubesd[2690]: File "/usr/lib/python3.13/site-packages/qubes/api/admin.py", line 85, in vm_handler
set 29 22:39:34 dom0 qubesd[2690]: self.send_event(subject, event, **kwargs)
set 29 22:39:34 dom0 qubesd[2690]: ~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^^^
set 29 22:39:34 dom0 qubesd[2690]: File "/usr/lib/python3.13/site-packages/qubes/api/__init__.py", line 441, in send_event
set 29 22:39:34 dom0 qubesd[2690]: self.transport.write("{}\0{}\0".format(k, str(v)).encode("ascii"))
set 29 22:39:34 dom0 qubesd[2690]: ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^^^^^^^^^
set 29 22:39:34 dom0 qubesd[2690]: UnicodeEncodeError: 'ascii' codec can't encode character '\xe3' in position 76: ordinal not in range(128)
