R4.3.1 update problem from R4.2.4
Running a Lenovo P50 with R4.2.4 installed. Attempted to update to R4.3.1 with the following results:
During the boot up display screen hung at the line:
“noveau 0000:01:00:0. MM10 read of 0000000 Fault at 001220 [PRIVRING]”
after about 2 min the boot continued with normal screens until it reached the partition screen. At that point it delivered the message:
“Unknown error”
and locked up
Like to have suggestions on how to proceed or diagnose the fault
  1. Backup a snapshot of the storage medium.
  2. Reinstall Qubes OS 4.3.1.
  3. Decrypt the snapshot and transfer any relevant files to the new Qubes OS installation.
FranklyFlawless
Thanks for your note and suggested steps. I can certainly get snapshots while running R4.2.4 but since I can not install R4.3.1 as noted above, I am unable to decrypt snapshots and do any transfer. Hence have not been able to move forward with R4.3.1.
Perhaps there is another way to deal with this issue?
Depends on what costs you are willing to bear against time and money.
