R4.3.0 clean install: 2 reproducible bugs
I took the time to fresh-reinstall a test laptop with R4.3.0, after playing with liteqube and other 3rd party stuff on the previous R4.3.0 install.
The reinstall was performed using the defaults with two exceptions:
1- used debian-13-xfce as default template (not fedora-42-xfce)
2- used a combined sys-net + sys-usb, disposable.
After the successful install and the customary “update everything including dom0” on the first boot, and another reboot, the following bugs are immediately apparent.
  1. The graphical USB widget (“Qubes Devices”) is pretty much unusable. It can attach ONCE a USB device to a qube, but then that particular device is gone - and cannot be detached, or re-attached, using the graphical interface.
    Note that after confirming that the bug is present when sys-net was using the Qubes-install-generated default-dvm using the debian-13-xfce template, I changed the dvm template to use fedora-42-xfce and the behavior is identical.
    This is mostly a “cosmetical” issue because and advanced user (like me, LOL) can use qvm-block to manipulate the USB devices without problems. I can see how this issue would aggravate someone not familiar with QubesOS, though.
  2. The (graphical) Qubes OS Global Config adds “Community Testing Templates” unprompted, on the first use(!)
    This is a head-scratcher for me. I (maybe) understand why the whonix-*- 18 templates are under the “Community Templates” repo - but there is no valid reason to sneakily enable “Community Testing Templates” on anybody!
Most of the USB gui/qui regressions seem to have disappeared, using a separate non-disposable sys-usb.
