[R4.2.4] dom0: strange PAM configuration
I noticed these PAM messages in the dom0 logs, along the lines of:
[...] PAM unable to dlopen(/usr/lib64/security/pam_sss.so): /usr/lib64/security/pam_sss.so: cannot open shared object file: No such file or directory
And, no surprise, that file does not exist.
A quick dnf query shows that the file is part of the sssd-client rpm, which is not installed in dom0! Nor is sssd, the respective daemon.
On further digging:
[user@dom0 ~]$ authselect list
- minimal	 Local users only for minimal installations
- nis    	 Enable NIS for system authentication
- sssd   	 Enable SSSD for system authentication (also for local users only)
- winbind	 Enable winbind for system authentication
[user@dom0 ~]$ authselect current
Profile ID: sssd
Enabled features:
- with-silent-lastlog
[user@dom0 ~]$
Now this is a weird configuration choice for a system like dom0, when you don’t plan on using network/ldap authentication… so probably it is just a bug.
Solutions: switching to the “minimal” profile (sudo authselect select minimal) or installing sssd-client (sudo qubes-dom0-update --releasever=4.2 sssd-client) or installing the full sssd system (sudo qubes-dom0-update --releasever=4.2 sssd)
That is indeed a very annoying bug and has been discussed before:
And I believe Marek had specific idea on the best way to fix it. But it just dropped to “Lower priority” category.
Yes, ok, for me this seems to work fine:
sudo authselect enable-feature with-silent-lastlog
Now I get no more PAM errors and the configuration is:
Profile ID: minimal
Enabled features:
Thanks, have long been intending to look into that error in the log. :+1:
Is it only a R4.2 issue ?
Because I don’t see these traces in my logs, and my current auth profile is local, not sssd.
ser@dom0:~$ authselect list
- local  	 Local users only
user@dom0:~$ authselect current
Profile ID: local
Enabled features:
- with-fingerprint
user@dom0:~$ cat /etc/qubes-release
Qubes release 4.3-rc3 (R4.3)
I don’t know, I never ran the 4.3 Release Candidates.
And that’s why I put in the thread title “[R4.2.4]” because it is where I discovered the issue.
My system is in-place upgraded to r4.3. And I do not see this in dom0 anymore. But I have the same error in TemplateVMs (or at least, some of them).
Oh yes, you have to fix this all over the place, in every template that uses PAM…
Note that newer Fedora versions call the simple/simplest auth profile “local”, not “minimal”.
