After migration to R4.1-rc1 my previously working VPN (openvpn) qube do not work anymore. Not sure why
It CAN connect to the server And I see this message:
Initialization Sequence Completed
WrWrWrWrWrWrWrWrWrWrWrWrWrWrWrWrWrWrWrWrWRrWrWrWrWrWrWrWrWrWrWrWrWrWrWrWrWrWrWrWrWrWrWrWrWr"
but network never works and after some time I see connection failed: No route to host and it try to reconnect.
Not sure how to fix it and what happened.
Previously, everything worked without troubles.
Already tried: 1) change ip range from 198.0.30.* to 10.8.0.*
2) recreate vpn AppVM.
3) change all scripts (qubes-firewall and vpn-handler) to actual versions from this: https://github.com/Qubes-Community/Contents/blob/master/docs/configuration/vpn.md
Maybe something changed at network rules (iptable, nat, route) related at R4.1?
I think that problem at ‘qubes-firewall-user-script’. It do not work anymore like expected.
update: tried with other openvpn instance that previously work. The same problem
update2: posted routes after connect below
