I might have found the cause, or at least of the network-driver part of them.
Summary: in Qubes Windows Tools as currently shipped for R4.3 (qubes-windows-tools-4.2.2-1.fc41, current in both qubes-dom0-currentand qubes-dom0-current-testing as of 2026-07-13; PV drivers version 9.1.0.0, DriverVer 04/07/2025), the xennet driver cannot bind to the network device enumerated by xenvif. The two components disagree about the child-device revision, so driver installation always fails with 0xE0000228: There are no compatible drivers for this device, which is exactly the “won’t update drivers even if directed to the correct inf/sys files” behaviour reported above. I verified this on my installation; since the mismatch is between files within the same package, it should be installation-independent.
The mismatch:
xennet.inf (published as oem5.inf on my system) contains exactly one binding per vendor:
%XenNetName% =XenNet_Inst, XENVIF\VEN_XP0001&DEV_NET&REV_09000005
%XenNetName% =XenNet_Inst, XENVIF\VEN_XP0002&DEV_NET&REV_09000005
But the running xenvif (same package; sc query xenvif reports RUNNING, and the “Xen PV Network Class” device reports “This device is working properly”) enumerates its child device with these hardware IDs, as recorded in setupapi.dev.log during a failed Update-driver attempt:
dvi: Searching for hardware ID(s):
dvi: xenvif\ven_xp0001&dev_net&rev_09000004
dvi: xenvif\ven_xp0001&dev_net&rev_09000003
dvi: xenvif\ven_xp0001&dev_net&rev_09000002
dvi: xenvif\ven_xp0001&dev_net&rev_09000001
dvi: xenvif\ven_xp0001&dev_net&rev_09000000
dvi: xendevice
! dvi: Error 0xe0000228: There are no compatible drivers for this device.
xennet requires revision 5; xenvif offers at most revision 4. No offered ID matches the INF, so the “XP0001 XENVIF 0” device stays under “Other devices” with Code 28, and Windows silently keeps using the emulated Realtek NIC. Pointing Update Driver at the QWT CD-ROM cannot help: the driver is found and staged (the log shows xennet 9.1.0.0 imported into the driver store from the same MSI run that installed xenvif 9.1.0.0), it just never claims the device.
Ruled out as causes:
- Local file corruption / stale binary:
xenvif.sys is byte-identical (SHA1 53ad695025993c5578d33ee14825f926e0b54aeb) in C:\Windows\System32\drivers\, in the DriverStore FileRepository, and in C:\Program Files\Qubes Tools\bin\pvdrivers\xenvif\.
- Phantom devnode with cached IDs: the DEV_NET child is live (not greyed out with hidden devices shown), enumerated by the running xenvif.
- Outdated package: 4.2.2-1.fc41 is the newest version in both stable and testing repos as of this post.
Conclusion: the packaged xenvif and xennet appear to have been built from different source states: the xenvif binary offers child revision 4 while xennet’s INF (and presumably binary) expects revision 5. If so, no R4.3 QWT installation can currently get a PV network adapter, and the failure is easy to miss because the emulated NIC keeps networking alive.
Environment: Qubes OS R4.3.1; Windows 11 24H2 (build 26100) as a TemplateVM created via qvm-create-windows-qube; QWT installed from the ISO in dom0’s qubes-windows-tools package.
