New qubes user here. I’m running a fresh Qubes 4.1 which seems to have installed the fedora 34 template by default. Since fedora 34 is EOL, I’m trying to get the fedora 36 template installed from the qubes repo. I’m following this guide: Templates | Qubes OS
When I try to run “sudo qubes-dom0-update qubes-template-fedora-36”, it gives me the following error:
qvm-template: error: Template ‘fedora-36’ not found.
When I try “qvm-template search fedora”, it only shows the version that is installed. I would guess there are problems with the repo configuration. Even trying “sudo qubes-dom0-update --clean -y” seems to have problems accessing repos. It’s giving errors as well, something like “Curl error 60 … certificate not yet valid”
Any help would be much appreciated.
