When I attempt to start my NixOS HVM it fails, but only sometimes.
I receive a notification that says Start failed: internal error: libxenlight failed to create new domain 'NixOS-00', see /var/log/libvirt/libxl/libxl-driver.log for details
2025-02-27 05:47:05.068+0000: libxl: libxl_pci.c:1587:libxl__device_pci_reset: The kernel doesn't support reset from sysfs for PCI device 0000:00:0d.0
2025-02-27 05:47:05.079+0000: libxl: libxl_pci.c:1587:libxl__device_pci_reset: The kernel doesn't support reset from sysfs for PCI device 0000:00:0d.2
2025-02-27 05:47:05.083+0000: libxl: libxl_pci.c:1587:libxl__device_pci_reset: The kernel doesn't support reset from sysfs for PCI device 0000:00:14.0
2025-02-27 09:11:04.818+0000: libxl: libxl_pci.c:1587:libxl__device_pci_reset: The kernel doesn't support reset from sysfs for PCI device 0000:00:0d.0
2025-02-27 09:11:04.933+0000: libxl: libxl_pci.c:1587:libxl__device_pci_reset: The kernel doesn't support reset from sysfs for PCI device 0000:00:0d.2
2025-02-27 09:11:05.047+0000: libxl: libxl_pci.c:1587:libxl__device_pci_reset: The kernel doesn't support reset from sysfs for PCI device 0000:00:14.0
2025-02-27 09:11:37.450+0000: libxl: libxl_pci.c:1587:libxl__device_pci_reset: The kernel doesn't support reset from sysfs for PCI device 0000:00:0d.0
2025-02-27 09:11:37.460+0000: libxl: libxl_pci.c:1587:libxl__device_pci_reset: The kernel doesn't support reset from sysfs for PCI device 0000:00:0d.2
2025-02-27 09:11:37.463+0000: libxl: libxl_pci.c:1587:libxl__device_pci_reset: The kernel doesn't support reset from sysfs for PCI device 0000:00:14.0
2025-02-27 09:14:02.123+0000: xc: panic: xg_dom_x86.c:1319: meminit_pv: failed to allocate 0x9000 pages: Internal error
2025-02-27 09:14:02.123+0000: xc: panic: xg_dom_boot.c:119: xc_dom_boot_mem_init: can't allocate low memory for domain: Out of memory
2025-02-27 09:14:02.123+0000: libxl: libxl_dom.c:586:libxl__build_dom: xc_dom_boot_mem_init failed: Device or resource busy
2025-02-27 09:14:02.124+0000: libxl: libxl_dm.c:2808:stubdom_pvqemu_cb: Domain 29:error connecting nics devices: Device or resource busy
2025-02-27 09:14:02.124+0000: libxl: libxl_create.c:1975:domcreate_devmodel_started: Domain 29:device model did not start: -3
2025-02-27 09:14:14.751+0000: libxl: libxl_domain.c:81:libxl__domain_rename: Domain 32:Domain with name "NixOS-00-dm" already exists.
2025-02-27 09:14:14.751+0000: libxl: libxl_dm.c:2808:stubdom_pvqemu_cb: Domain 31:error connecting nics devices: Function not implemented
2025-02-27 09:14:14.751+0000: libxl: libxl_create.c:1975:domcreate_devmodel_started: Domain 31:device model did not start: -6
2025-02-27 09:14:32.311+0000: libxl: libxl_domain.c:81:libxl__domain_rename: Domain 34:Domain with name "NixOS-00-dm" already exists.
2025-02-27 09:14:32.311+0000: libxl: libxl_dm.c:2808:stubdom_pvqemu_cb: Domain 33:error connecting nics devices: Function not implemented
2025-02-27 09:14:32.311+0000: libxl: libxl_create.c:1975:domcreate_devmodel_started: Domain 33:device model did not start: -6
2025-02-27 15:16:27.688+0000: libxl: libxl_domain.c:81:libxl__domain_rename: Domain 50:Domain with name "NixOS-00-dm" already exists.
2025-02-27 15:16:27.688+0000: libxl: libxl_dm.c:2808:stubdom_pvqemu_cb: Domain 49:error connecting nics devices: Function not implemented
2025-02-27 15:16:27.688+0000: libxl: libxl_create.c:1975:domcreate_devmodel_started: Domain 49:device model did not start: -6
2025-02-27 15:50:56.636+0000: libxl: libxl_domain.c:81:libxl__domain_rename: Domain 52:Domain with name "NixOS-00-dm" already exists.
2025-02-27 15:50:56.637+0000: libxl: libxl_dm.c:2808:stubdom_pvqemu_cb: Domain 51:error connecting nics devices: Function not implemented
2025-02-27 15:50:56.637+0000: libxl: libxl_create.c:1975:domcreate_devmodel_started: Domain 51:device model did not start: -6
2025-02-27 15:51:43.619+0000: libxl: libxl_domain.c:81:libxl__domain_rename: Domain 54:Domain with name "NixOS-00-dm" already exists.
2025-02-27 15:51:43.620+0000: libxl: libxl_dm.c:2808:stubdom_pvqemu_cb: Domain 53:error connecting nics devices: Function not implemented
2025-02-27 15:51:43.620+0000: libxl: libxl_create.c:1975:domcreate_devmodel_started: Domain 53:device model did not start: -6
2025-02-27 15:51:57.772+0000: libxl: libxl_domain.c:81:libxl__domain_rename: Domain 56:Domain with name "NixOS-00-dm" already exists.
2025-02-27 15:51:57.772+0000: libxl: libxl_dm.c:2808:stubdom_pvqemu_cb: Domain 55:error connecting nics devices: Function not implemented
2025-02-27 15:51:57.773+0000: libxl: libxl_create.c:1975:domcreate_devmodel_started: Domain 55:device model did not start: -6
2025-02-27 16:01:10.080+0000: libxl: libxl_domain.c:81:libxl__domain_rename: Domain 58:Domain with name "NixOS-00-dm" already exists.
2025-02-27 16:01:10.081+0000: libxl: libxl_dm.c:2808:stubdom_pvqemu_cb: Domain 57:error connecting nics devices: Function not implemented
2025-02-27 16:01:10.081+0000: libxl: libxl_create.c:1975:domcreate_devmodel_started: Domain 57:device model did not start: -6
Above are the logs across the full day and attempting start several times.
I’m not out of memory. Giving it less memory or turning off memory sharing has no effect. I suspect something has not fully shutdown since this never happens on first qvm-start.
I have more than enough ram. i tried lowering it by over 30 gbs and it still fails. I don’t think it’s the problem and that error doesn’t show back up when it is raised.
No window shows. There are no devices connected.
prefs
audiovm D dom0
autostart - False
backup_timestamp U
debug D False
default_dispvm D default-dvm
default_user D user
dns D 10.139.1.1 10.139.1.2
gateway D
gateway6 D
guivm D dom0
icon D standalonevm-blue
include_in_backups D True
installed_by_rpm D False
ip D 10.137.0.80
ip6 D
kernel -
kernelopts D
keyboard_layout D us++
klass D StandaloneVM
label - blue
mac D 00:16:3e:5e:6c:00
management_dispvm D default-mgmt-dvm
maxmem - 50000
memory - 8192
name - NixOS-00
netvm D ndisp-mul-net-02
provides_network D False
qid - 80
qrexec_timeout D 60
shutdown_timeout D 60
start_time D
stubdom_mem U
stubdom_xid D -1
template_for_dispvms D False
updateable D True
uuid - 6224cd85-4bd3-46e1-9824-b319687cd719
vcpus - 12
virt_mode - hvm
visible_gateway D 10.138.18.120
visible_gateway6 D
visible_ip D 10.137.0.80
visible_ip6 D
visible_netmask D 255.255.255.255
xid D -1
wait wtf are those devices in the error log?
they are my usb controllers. Why are they connected at all?
dom0:00_0d.2 USB controller: Intel Corporation Raptor Lake-P Thunderbolt 4 NHI #0
and
dom0:00_14.0 USB controller: Intel Corporation Alder Lake PCH USB 3.2 xHCI Host Controller
what does it meaaaan
2024-12-16 23:18:04.382+0000: libxl: libxl_pci.c:1587:libxl__device_pci_reset: The kernel doesn't support reset from sysfs for PCI device 0000:00:0d.2
2024-12-16 23:18:04.388+0000: libxl: libxl_pci.c:1587:libxl__device_pci_reset: The kernel doesn't support reset from sysfs for PCI device 0000:00:14.0
2024-12-16 23:19:16.398+0000: libxl: libxl_pci.c:1582:libxl__device_pci_reset: write to /sys/bus/pci/devices/0000:00:14.3/reset returned -1: Inappropriate ioctl for device
2024-12-16 23:19:17.535+0000: libxl: libxl_qmp.c:1837:qmp_ev_parse_error_messages: Domain 32:Could not open '/sys/bus/pci/devices/0000:00:01.3/config': No such file or directory
2024-12-16 23:19:17.536+0000: libxl: libxl_pci.c:1275:pci_add_qmp_device_add_cb: Domain 32:Retrying PCI add 1
2024-12-16 23:19:18.608+0000: libxl: libxl_qmp.c:1837:qmp_ev_parse_error_messages: Domain 32:Could not open '/sys/bus/pci/devices/0000:00:01.3/config': No such file or directory
2024-12-16 23:19:18.608+0000: libxl: libxl_pci.c:1275:pci_add_qmp_device_add_cb: Domain 32:Retrying PCI add 2
2024-12-16 23:19:19.680+0000: libxl: libxl_qmp.c:1837:qmp_ev_parse_error_messages: Domain 32:Could not open '/sys/bus/pci/devices/0000:00:01.3/config': No such file or directory
2024-12-16 23:19:19.681+0000: libxl: libxl_pci.c:1275:pci_add_qmp_device_add_cb: Domain 32:Retrying PCI add 3
2024-12-16 23:19:20.752+0000: libxl: libxl_qmp.c:1837:qmp_ev_parse_error_messages: Domain 32:Could not open '/sys/bus/pci/devices/0000:00:01.3/config': No such file or directory
2024-12-16 23:19:20.753+0000: libxl: libxl_pci.c:1275:pci_add_qmp_device_add_cb: Domain 32:Retrying PCI add 4
2024-12-16 23:19:21.824+0000: libxl: libxl_qmp.c:1837:qmp_ev_parse_error_messages: Domain 32:Could not open '/sys/bus/pci/devices/0000:00:01.3/config': No such file or directory
2024-12-16 23:19:21.824+0000: libxl: libxl_pci.c:1275:pci_add_qmp_device_add_cb: Domain 32:Retrying PCI add 5
2024-12-16 23:19:22.896+0000: libxl: libxl_qmp.c:1837:qmp_ev_parse_error_messages: Domain 32:Could not open '/sys/bus/pci/devices/0000:00:01.3/config': No such file or directory
2024-12-16 23:19:22.897+0000: libxl: libxl_pci.c:1275:pci_add_qmp_device_add_cb: Domain 32:Retrying PCI add 6
2024-12-16 23:19:23.968+0000: libxl: libxl_qmp.c:1837:qmp_ev_parse_error_messages: Domain 32:Could not open '/sys/bus/pci/devices/0000:00:01.3/config': No such file or directory
2024-12-16 23:19:23.968+0000: libxl: libxl_pci.c:1275:pci_add_qmp_device_add_cb: Domain 32:Retrying PCI add 7
2024-12-16 23:19:25.039+0000: libxl: libxl_qmp.c:1837:qmp_ev_parse_error_messages: Domain 32:Could not open '/sys/bus/pci/devices/0000:00:01.3/config': No such file or directory
2024-12-16 23:19:25.040+0000: libxl: libxl_pci.c:1275:pci_add_qmp_device_add_cb: Domain 32:Retrying PCI add 8
2024-12-16 23:19:26.112+0000: libxl: libxl_qmp.c:1837:qmp_ev_parse_error_messages: Domain 32:Could not open '/sys/bus/pci/devices/0000:00:01.3/config': No such file or directory
2024-12-16 23:19:26.113+0000: libxl: libxl_pci.c:1275:pci_add_qmp_device_add_cb: Domain 32:Retrying PCI add 9
2024-12-16 23:19:27.183+0000: libxl: libxl_qmp.c:1837:qmp_ev_parse_error_messages: Domain 32:Could not open '/sys/bus/pci/devices/0000:00:01.3/config': No such file or directory
2024-12-16 23:19:27.184+0000: libxl: libxl_pci.c:1275:pci_add_qmp_device_add_cb: Domain 32:Retrying PCI add 10
2024-12-16 23:19:27.318+0000: libxl: libxl_pci.c:1864:device_pci_add_done: Domain 32:libxl__device_pci_add failed for PCI device 0:0:14.3 (rc -9)
2024-12-16 23:19:27.319+0000: libxl: libxl_create.c:2000:domcreate_attach_devices: Domain 32:unable to add pci devices
2024-12-16 23:20:38.257+0000: libxl: libxl_pci.c:1582:libxl__device_pci_reset: write to /sys/bus/pci/devices/0000:00:14.3/reset returned -1: Inappropriate ioctl for device
2024-12-16 23:20:48.322+0000: libxl: libxl_device.c:1507:libxl__wait_for_backend: Backend /local/domain/0/backend/pci/33/0 not ready
2024-12-16 23:20:58.334+0000: libxl: libxl_device.c:1218:device_backend_callback: Domain 33:unable to remove device with path /local/domain/0/backend/vbd/33/51712
2024-12-16 23:20:58.339+0000: libxl: libxl_device.c:1218:device_backend_callback: Domain 33:unable to remove device with path /local/domain/0/backend/vbd/33/51728
2024-12-16 23:20:58.341+0000: libxl: libxl_device.c:1218:device_backend_callback: Domain 33:unable to remove device with path /local/domain/0/backend/vbd/33/51744
2024-12-16 23:20:58.345+0000: libxl: libxl_device.c:1218:device_backend_callback: Domain 33:unable to remove device with path /local/domain/0/backend/vbd/33/51760
2024-12-16 23:20:58.348+0000: libxl: libxl_domain.c:1589:devices_destroy_cb: Domain 33:libxl__devices_destroy failed
2024-12-16 23:20:58.368+0000: libxl: libxl_device.c:1218:device_backend_callback: Domain 32:unable to remove device with path /local/domain/0/backend/vbd/32/51712
2024-12-16 23:20:58.370+0000: libxl: libxl_device.c:1218:device_backend_callback: Domain 32:unable to remove device with path /local/domain/0/backend/vbd/32/51728
2024-12-16 23:20:58.371+0000: libxl: libxl_device.c:1218:device_backend_callback: Domain 32:unable to remove device with path /local/domain/0/backend/vbd/32/51744
