Qvm-run - command failed with code: 2 (indention error)
I am experimenting with qvm-run. If am doing something like this:
if <some condition>; then
  qvm-run -u user disp4801 "
  echo hello
  echo hello2
fi
, I’ll get
“command failed with code: 2”
Note the indention for the if statement and the " at its own line for code style aspects.
I need to change to
  echo hello
  echo hello2"
fi
(" at end of existing line)
Whereas following works:
echo hello
echo hello2
My reference comparison is bash, where indention with " in new line also works without problems:
  bash -c "
  echo hello
  echo hello2
Background: I needed half an hour to find this tricky to debug error in my shell scripts.
What is the reason for qvm-run complaining?
You’ll have the same error with this command:
echo hello
echo hello2
Because it’ll execute space as a command at the end and it’ll return error code 2:
[user@dom0 ~]$
[user@dom0 ~]$ echo $?
2
Ah thanks!
Wouldn’t it then make sense to make qvm-run behave just like bash/sh and other shells, which don’t interpret trailing whitespace as new command?
Just somethink like a trim at the end.
You can open enhancement request here so that devs can consider it:
Crosslinked issue: https://github.com/QubesOS/qubes-issues/issues/7607
qvm-run is meant to run a single command. If you want sh -c behavior, use sh -c as that single command, for example:
qvm-run -- <vmname> sh -c "whatever you want, possibly multiline".
