Problem
File downloaded to personal qube, based on fedora-38-xfce (created by installer) is not possible to move using qvm-move nor gvm-copy to a different qube. Commands fail with Request refused.
This is the fresh 4.2 installation. I have no backup of dom0. I’m trying to run Trezor Suite and trezord-service is part of it. I will confirm the validity of the file and let you know. Thank you for your time.
This is a follow-up proposed solution. The problem was caused by command "$anyvm $anyvm allow,user=trezord,target=sys-usb" > /etc/qubes-rpc/policy/trezord-service causing system to take anyvm as a variable. The author of tutorial has released a newer version addresing this syntax error, accessible here: smrtak: updated version with fixed issues: # TrezorSuite ...
The solution is to use '@anyvm @anyvm allow,user=trezord,target=sys-usb' > /etc/qubes-rpc/policy/trezord-service instead or edit file manually.
