Hi! I’ve recently tried to establish TCP connections between two qubes with fedora-39-minimal template via RPC protocols, in Qubes 4.2.0
I’ve correctly created a new policy file with proper rule as said in file /etc/qubes/policy.d/90-default.policy
Also i’ve installed as said here: Minimal templates | Qubes OS
However I still cannot establish a TCP connection via tcp between this two qubes with minimal templates. What i am doing wrong?
As shown in this picture, curl fails. I suspect something is happening with the minimal template because changing both qubes templates to fedora-39-xfce templates works perfectly
I’ve successfully established the same connection but changing both qubes templates to default fedora-39-xfce template (i perfectly receive HTTP response in “cliente” qube)
There must be many packages i don’t figure out to install or something strange i have no idea about
Please only answer me solutions, no need security awareness
Thanks in advance
