What is the quickest way to see the total free space for an entire system drive not for just an VM?
When I run thunar in dom0, I’m not seeing it and i’m not seeing in qubes manager
i estimate i’ve use 30 percent of space but want exact number
Disk space widget (drive icon in notification area).
I use the i3 window manager and there’s a script for displaying the free disk space in the i3 status bar.
Here’s the function in the script that calculates free disk space, if you’re interested in a quick way to do so via the command line:
status_disk() {
local disk=''
local free=''
local size=''
local usage=''
read size <<< $(qvm-pool -i $(qubes-prefs default-pool) | grep 'size' | sort | awk '{print $2}')
read usage <<< $(qvm-pool -i $(qubes-prefs default-pool) | grep 'usage' | sort | awk '{print $2}')
free=$(($size - $usage))
case ${#free} in
1[3-5])
disk="$(($free / 1099511627776))T" ;;
1[0-2])
disk="$(($free / 1073741824))G" ;;
[7-9])
disk="$(($free / 1048576))M" ;;
[4-6])
disk="$(($free / 1024))K" ;;
[1-3])
disk="$free Bytes" ;;
disk="Error" ;;
esac
json disk "Disk free: $disk"
The core info is determined in the size and usage variables.
