Snowflake running in Tor Control Panel.
18/12/2024 EDIT: I have had to change the first command twice now from “qvm-copy-to-vm” to “qvm-copy”, and back to “qvm-copy-to-vm”. It is now “qvm-copy-to-vm”.
Here is the summarized and easily readable version of my Qubes-Whonix-17 Tor Control Panel snowflake proxy fix/installation guide. The full version of my guide can be found at the bottom of the page. The next Whonix release likely will not need this procedure.
Qubes-Whonix Tor Control Panel with working Snowflake Proxy
Quick Start Guide
1) whonix-workstation-17 template terminal:
Copy updated snowflake-client to gateway template from workstation template:
qvm-copy-to-vm whonix-gateway-17 /var/cache/tb-binary/.tb/tor-browser/Browser/TorBrowser/Tor/PluggableTransports/snowflake-client
A pop up window will appear with the selection to put the files in a qube. Select 'whonix-gateway-17 template.
2) whonix-gateway-17 template terminal:
Copy updated snowflake client to /usr/bin, make executable, use nano to edit bridges file:
sudo cp ~/QubesIncoming/whonix-workstation-17/snowflake-client /usr/bin/snowflake-client
sudo chmod og+rx /usr/bin/snowflake-client
sudo nano /usr/share/anon-connection-wizard/bridges_default
Replace Snowflake Bridges with:
Click to show
"Bridge snowflake 192.0.2.3:80
2B280B23E1107BB62ABFC40DDCC8824814F80A72
fingerprint=2B280B23E1107BB62ABFC40DDCC8824814F80A72
url=https://1098762253.rsc.cdn77.org/
fronts=docs.plesk.com,www.phpmyadmin.net
ice=stun:stun.l.google.com:19302,stun:stun.antisip.com:3478,stun:stun.bluesip.net:3478,stun:stun.dus.net:3478,stun:stun.epygi.com:3478,stun:stun.sonetel.com:3478,stun:stun.uls.co.za:3478,stun:stun.voipgate.com:3478,stun:stun.voys.nl:3478
utls-imitate=hellorandomizedalpn", "Bridge snowflake 192.0.2.4:80
8838024498816A039FCBBAB14E6F40A0843051FA
fingerprint=8838024498816A039FCBBAB14E6F40A0843051FA
ice=stun:stun.l.google.com:19302,stun:stun.antisip.com:3478,stun:stun.bluesip.net:3478,stun:stun.dus.net:3478,stun:stun.epygi.com:3478,stun:stun.sonetel.net:3478,stun:stun.uls.co.za:3478,stun:stun.voipgate.com:3478,stun:stun.voys.nl:3478
Save & exit
5) Shutdown whonix-gateway-17 template
6) Restart sys-whonix
7) Start Tor Control Panel
Click “Stop Tor”
Click “Configure”
Select “Bridges type” → “snowflake”
Click “Restart Tor”
Enjoy Snowflake on Qubes-Whonix working the way it’s supposed to be! ![]()
Here is my original guide:
Thanks to @glockmane for summarizing AND formatting the guide!
