Sorry all but this will be a noob question, and I hope it is appropriately placed in General Discussion.
I’m currently running Qubes OS on a pwned network (for certain), with presumably pwned hardware just to get a feel for it rather than an absolute need for security (as I’m expected to get compromised), but I’ve just had an update for a Fedora template I cloned come up and the packages were all referencing remote connections & keepassxc, listed below.
I’ve enabled updates over tor, and as I said I am on a pwned network with an expectation that i’ll get compromised eventually, but this update just seemed to refer to a bunch of remote connection type of packages which seems suspicious given the context I provided.
So is this normal? Is there a way to inspect the changes? If it is odd, is there a way to check what updates in other template VM’s I may have inadvertently accepted of this sort? If it isn’t odd at all, is there a reason all these related packages were requested to be updates simultaneously?
Thanks a bunch of the advice, and the other informative discussions around here I’ve learned from. Love Qubes and looking forward to learning a lot more about how to use it!
Upgrading:
gnome-control-center ------------- x86_64 40.9-1.fc34 5.5m
gnome-control-center-filesystem x86_64 40.9-1.fc34 11k
keepassxc --------------------------- x86_64 2.6.6-5.fc34 6.3m
perl-module-corelist ---------------- noarch 1:5.20220220-1.fc34 83k
perl-module-corelist-tools --------- noarch 1:5.20220220-1.fc34 18k
selinux-policy ------------------------ x86_64 34.26-1.fc34 63k
selinux-policy.targeted------------- noarch 34.26-1fc34 6.3m
Installating dependences:
freerdp-libs x86_64 2:2.5.0-1.fc34 998k
libvncserver - 0.9.13-10.fc34 300k
libwinpr - 40.2-2.fc34 95k
Installing weak dependencies:
gnome-remote-desktop x86_64 40.2-2.fc34
Install 4 Packages
Upgrade 7 Packages
Total size 20m
Download size 6.3m
To add, they all said they were from “updates” repo apart from ‘libvncserver’ which was from “fedora”
